查看: 10576|回复: 0
问个问题 卡你看
发表于 2013-11-9 00:33:52 | 显示全部楼层 |阅读模式
最近在用arduino 弄一个三轴磁场的程序,弄出来后有三个值如x=126,y=125
z=58,我想反映出磁场的变化就把他合并为x2+y2+z2再开根号,但是这样发现 合并为一个结果反映的时候,变化相当的大,我想问下能不能有x轴现在的数字与x轴0.5秒前的数值相减,根据变化量来做出点亮led灯的控制(同轴变化量),谢谢
以前的老大妈是这个#include <Wire.h> //I2C Arduino Library
#define address 0x1E //0011110b, I2C 7bit address of HMC5883
int ledPin = 13;
void setup(){
  //Initialize Serial and I2C communications
  Wire.begin();
  //Put the HMC5883 IC into the correct operating mode
  Wire.beginTransmission(address); //open communication with HMC5883
  Wire.write(0x02); //select mode register
  Wire.write(0x00); //continuous measurement mode
  Wire.endTransmission();
void loop(){
  int x,y,z,baa,all; //triple axis data
  //Tell the HMC5883 where to begin reading data
  Wire.write(0x03); //select register 3, X MSB register
//Read data from each axis, 2 registers per axis
  Wire.requestFrom(address, 6);
  if(6<=Wire.available()){
    x = Wire.read()<<8; //X msb
    x |= Wire.read(); //X lsb
    z = Wire.read()<<8; //Z msb
    z |= Wire.read(); //Z lsb
    y = Wire.read()<<8; //Y msb
    y |= Wire.read(); //Y lsb
    baa=sq(x) + sq(y)+ sq(z) ;
    all=sqrt(baa);
  if(all>190){
    digitalWrite(13,HIGH);
   Serial.print("abs(all): ");
   Serial.print(abs(all));
   delay(5000);
      digitalWrite(13,LOW);
delay(5000);
GMT+8, 2026-7-28 04:19 , Processed in 0.037316 second(s), 17 queries .
