查看: 13638|回复: 2
发表于 2013-11-10 00:08:43 | 显示全部楼层 |阅读模式
arduino 用hmc5883l 磁场传感器,接线A4 和A5 后,编程序,用led 13灯来点亮,但是实实验中,当模拟数字符合点亮的条件的时候,为什么外接在13号引脚的led灯不会亮呢,而且有时候是处于微微亮的状态(一直微亮),代码如下
#include <Wire.h> //I2C Arduino Library
#define address 0x1E //0011110b, I2C 7bit address of HMC5883
int ledPin1 = 13;
void setup(){
  //Initialize Serial and I2C communications
  Wire.begin();
  //Put the HMC5883 IC into the correct operating mode
  Wire.beginTransmission(address); //open communication with HMC5883
  Wire.write(0x02); //select mode register
  Wire.write(0x00); //continuous measurement mode
  Wire.endTransmission();
void loop(){
  int x,y,z,baa,all; //triple axis data
  //Tell the HMC5883 where to begin reading data
  Wire.write(0x03); //select register 3, X MSB register
//Read data from each axis, 2 registers per axis
  Wire.requestFrom(address, 6);
  if(6<=Wire.available()){
    x = Wire.read()<<8; //X msb
    x |= Wire.read(); //X lsb
    z = Wire.read()<<8; //Z msb
    z |= Wire.read(); //Z lsb
    y = Wire.read()<<8; //Y msb
    y |= Wire.read(); //Y lsb
    all=x+y+z;
  if(all> 800)// 设置数值大于800  {
    digitalWrite(ledPin1,HIGH);
    Serial.print("abs(all): ");
   Serial.print(abs(all));
   delay(5000);
      digitalWrite(ledPin1,LOW);
delay(5000);
问题:当all的值已经达到1200的时候(已经大于800啦),为什么led13灯不会亮呢???????????[/size]
 楼主| 发表于 2013-11-10 02:08:35 | 显示全部楼层
为什么没有回答的
发表于 2013-11-10 06:50:46 来自手机 | 显示全部楼层
你把low和high互换试试?
GMT+8, 2026-7-28 05:15 , Processed in 0.032550 second(s), 18 queries .
