查看: 9474|回复: 1
求助,IDE 1.0.5 与 mwc2.2的问题!
发表于 2013-11-13 21:10:23 | 显示全部楼层 |阅读模式
校验代码:先是
getestimatedaltitude`was not declared in this scope
然后里面是这些个错误:
MultiWii.ino: In function 'void loop()':
MultiWii:1191: error: 'getEstimatedAltitude' was not declared in this scope
MultiWii:1214: error: 'computeIMU' was not declared in this scope
Sensors.ino: In function 'void Baro_Common()':
Sensors:717: error: 'BARO_TAB_SIZE' was not declared in this scope
Sensors:722: error: 'baroHistTab' was not declared in this scope
config.h里我已经改了些参数,只是我不知道飞控我该选哪个(我用的是2560的板子)
但是几乎同样的设置,我在公司的电脑里却正常编译通过!
实在没法子了,在网上搜半天了,也没找出个啥解决方法出来!
系统都是XP的!
 楼主| 发表于 2013-11-13 22:02:52 | 显示全部楼层
无语,把网上下的2.2程序重新解压,替换,竟然又可以了!
GMT+8, 2026-7-28 00:39 , Processed in 0.036031 second(s), 17 queries .
