查看: 13332|回复: 9
小米加OTG加PL2303加山寨Arduino加18B20
发表于 2013-11-16 23:24:40 来自手机 | 显示全部楼层 |阅读模式
  1. <P>#include <OneWire.h>
  2. // OneWire DS18S20, DS18B20, DS1822 Temperature Example
  3. //
  4. // http://www.pjrc.com/teensy/td_libs_OneWire.html
  5. //
  6. // The DallasTemperature library can do all this work for you!
  7. // http://milesburton.com/Dallas_Temperature_Control_Library
  8. OneWire ds(2); // on pin 10
  9. void setup(void)
  10. {
  11.     Serial.begin(9600);
  12.     //pinMode(2,OUTPUT);
  13.     //digitalWrite(2,HIGH);
  14. }
  15. void loop(void)
  16. {
  17.     byte i;
  18.     byte present = 0;
  19.     byte type_s;
  20.     byte data[12];
  21.     byte addr[8];
  22.     float celsius, fahrenheit;
  23.     if ( !ds.search(addr))
  24.     {
  25.         Serial.println("No more addresses.");
  26.         Serial.println();
  27.         ds.reset_search();
  28.         delay(250);
  29.         return;
  30.      }
  31.     Serial.print("ROM =");
  32.     for( i = 0; i < 8; i++)
  33.    {
  34.         Serial.write(' ');
  35.         Serial.print(addr[i], HEX);
  36.    }
  37.    if (OneWire::crc8(addr, 7) != addr[7])
  38.   {
  39.      Serial.println("CRC is not valid!");
  40.      return;
  41.   }
  42.    Serial.println();
  43.   // the first ROM byte indicates which chip
  44.   switch (addr[0])
  45. {
  46.     case 0x10:
  47.     Serial.println(" Chip = DS18S20"); // or old DS1820
  48.     type_s = 1;
  49.     break;
  50.     case 0x28:
  51.     Serial.println(" Chip = DS18B20");
  52.     type_s = 0;
  53.     break;
  54.     case 0x22:
  55.     Serial.println(" Chip = DS1822");
  56.     type_s = 0;
  57.     break;
  58.     default:
  59.     Serial.println("Device is not a DS18x20 family device.");
  60.     return;
  61. }
  62.    ds.reset();
  63.   ds.select(addr);
  64.   ds.write(0x44,1); // start conversion, with parasite power on at the end
  65.   delay(2000); // maybe 750ms is enough, maybe not
  66.   // we might do a ds.depower() here, but the reset will take care of it.
  67.   present = ds.reset();
  68.   ds.select(addr);
  69.   ds.write(0xBE); // Read Scratchpad
  70.   Serial.print(" Data = ");
  71.   Serial.print(present,HEX);
  72.   Serial.print(" ");
  73.   for ( i = 0; i < 9; i++)
  74. {</P>
  75. <P>    // we need 9 bytes
  76.    data[i] = ds.read();
  77.    Serial.print(data[i], HEX);
  78.    Serial.print(" ");
  79. }
  80.   Serial.print(" CRC=");
  81.   Serial.print(OneWire::crc8(data, 8), HEX);
  82.   Serial.println();
  83. </P>
  84. <P>  // convert the data to actual temperature
  85.   unsigned int raw = (data[1] << 8) | data[0];
  86.   if (type_s)
  87.   {
  88.      raw = raw << 3; // 9 bit resolution default
  89.      if (data[7] == 0x10)
  90.      {
  91.         // count remain gives full 12 bit resolution
  92.          raw = (raw & 0xFFF0) + 12 - data[6];
  93.       }
  94.   } </P>
  95. <P>    else
  96.    {
  97.         byte cfg = (data[4] & 0x60);
  98.         if (cfg == 0x00) raw = raw << 3; // 9 bit resolution, 93.75 ms
  99.         else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
  100.         else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
  101.         // default is 12 bit resolution, 750 ms conversion time
  102.    }
  103.       celsius = (float)raw / 16.0;
  104.       fahrenheit = celsius * 1.8 + 32.0;
  105.       Serial.print(" Temperature = ");
  106.       Serial.print(celsius);
  107.       Serial.print(" Celsius, ");
  108.       Serial.print(fahrenheit);
  109.       Serial.println(" Fahrenheit");
  110. }</P>
折腾成功,优酷视频审核中来自: iPhone客户端
发表于 2013-11-17 00:43:45 | 显示全部楼层
沙发抢到了!
发表于 2013-11-17 10:50:57 来自手机 | 显示全部楼层
这个,是高级货
发表于 2013-11-17 11:45:56 | 显示全部楼层
高手救命,如何把arduino中的float数据通过串口,传到processing中,并还原为float?????
发表于 2013-11-17 13:24:48 | 显示全部楼层
这个apk是什么诶
 楼主| 发表于 2013-11-17 20:27:41 来自手机 | 显示全部楼层
fuwen0202 发表于 2013-11-17 13:24
这个apk是什么诶
串口调试工具。
 楼主| 发表于 2013-11-17 20:30:06 来自手机 | 显示全部楼层
我是纯手艺人,程序不行。我是手艺加百度。
发表于 2013-11-22 12:36:23 | 显示全部楼层
PL2303插手机不需要驱动么?
发表于 2013-11-22 22:18:58 | 显示全部楼层
楼主可以上传你的手机端的程序apk文件吗,找了好几个都是蓝牙串口,或者发到我的邮箱[email protected],十分感谢!
发表于 2013-11-23 23:03:57 | 显示全部楼层
呃,小米otg的串口号是啥。。4
GMT+8, 2026-7-28 03:32 , Processed in 0.039143 second(s), 25 queries .
