查看: 30877|回复: 2
Makerbot 3D打印机装配教程 10.MakerBot Gen 4 LCD Interface (Optional)
发表于 2012-4-13 22:51:52 | 显示全部楼层 |阅读模式
Overview
The MakerBot Gen4 Interface board is a DIY addition to your MakerBot Thing-O-Matic that will allow you to interact directly with the machine. It has multiple buttons, multiple LEDs, and a 16×4 character LCD screen to provide feedback directly to you. Using this board, it is possible to run your MakerBot completely independently with no computer attached. You can set and read the temperature, view the progress of a build, and even start a new build from a file stored on the SD card. Of course you can also hack the firmware to make it anything else you might want as well.
This kit is DIY, and soldering is required. All the components are through-hole, so it is a great kit for beginners.
Features16×4 Character LCD
The main output method for the Gen4 Interface board is the LCD. This screen can display 4 lines of text, with 16 characters per line. That gives us a grand total of 64 characters to work with, although scrolling to display more text is very simple to do.
Tip: If your interface just shows strange characters at startup, hit the reset button on your motherboard — a reset will usually clear it right up.
Buttons, We Need Buttons
There are 9 buttons on the interface board, and they can be programmed to do whatever you want. Typically they will be programmed to move your bot around, navigate menus, and alter settings. We chose a nice, beefy button with a satisfying click.
LEDs, Lots of LEDs
There are 4 LEDs on the interface board: Power, Debug, Foo, and Bar. Power tells you the interface board is on, Debug is connected to the Arduino MEGA debug pin (D13). Foo and Bar are extra LEDs that are user definable and can be programmed to do whatever you’d like.
Note: the Debug LED will blink steadily to indicate normal operation.  We know a lot of people just leave these sorts of things off for normal operation, but we like blinking lights.
Contrast
Setting the contrast on the LCD screen is accomplished using a screwdriver on the blue potentiometer on the board. You can adjust the contrast by rotating the dial on the trimpot.
Interface Connector
This 20 pin IDC header contains all the LCD, button, and LED signals as well as 5V and GND. Using this header is how you control the LCD screen and read data from the buttons. It is a simple 2×10 header with standard 0.100″ pitch between pins. This makes interfacing it with your own custom stuff a simple, straightforward task.
Tip: if your LCD panel isn’t lighting up, then you’ve plugged this in the wrong way.  Turn it 180 degrees!
Identify Your Parts!
It is a good idea to get to know your parts before you build the interface kit. You’ll be able to tell if you’re missing any parts, and you’ll be able to quickly find each part as you need it. It is recommended to spread them out on a clean, level table that has nothing else on it.
PCB
LCD Screen
Components
IDC Cable Kit
Hardware
Lasercut Parts
Build It1K Ohm Resistors
These resistors have a color code of Brown – Black – Red – Gold. Orientation is not important, solder in any direction.
10K Ohm Resistors
These resistors have a color code of Brown – Black – Orange – Gold. Orientation is not important, solder in any direction.
Trimpot
This component will only fit one way. Insert it and solder away!
Red and Green LEDs
The bottom circle of the LED is flattened on one side. This side should match the silkscreen and face towards the 1K resistor next to it. Make sure you insert it in the correct orientation.
Put caps on Buttons
Just clip the cap on each of your buttons!  They should press on with a nice click.
Buttons
The buttons will only fit with the metal leads on either side and they snap into place. Make sure the pegs on the bottom of the buttons line up with the holes in the PCB. Also make sure that the number 1-4 on each corner match up with the numbers screened on the board. Be careful not to smash the legs as you insert them into the PCB.
IDC Header
Keeping the board flipped over, insert the IDC header as shown. The notch in the connector should face the inside of the board.
This is another place to try putting the headers on the board, then propping up the opposite side with a scrap part.
Prepare/Strip LCD Connector Wires
First carefully remove one conductor from the 15-pin wire.  Don’t remove the one with the red stripe.
Now, score the end of the ribbon cable in a straight line.
Score both sides of both ends as shown.
Next, clip the cable between each of the wires.
Now use a pair of needle-nose pliers to pull off the scored, cut tabs.
Attach Ribbon Cable to LCD
Now slot the ribbon cable directly into the LCD unit.
Solder directly to the board.
Attach Ribbon Cable to Controller Board
Insert the ribbon cable into the outermost holes.  There will be two extra holes near the blue connector; that’s OK.
Solder this in place normally.
Tape T-slots (Optional)
If you want to make your life easier during final assembly, tape the top side of the t-slots now.
Next, insert nuts into the opposite side and then tape over them again. This will hold everything in place while you build the rest of the enclosure.
Insert M2 Bolts
Insert the M2 x 16 mm and M3 x 22 mm bolts facing upwards as shown.
Add Spacers
Drop 4 of the tall spacers over each of the bolts as shown.
Fold LCD Cable
Fold your LCD cable so that the boards are as close together as possible. Make sure to give your cable a good, solid crease.
Add Interface Board Assembly
Now drop your boards into place; fit the bolts through all the holes.
Add Nuts for LCD Board
Add the nuts here to hold the LCD in place.
Add Thin Spacers
Add the remaining thin spacers.
Attach Acrylic Top
Finally top it off with the clear acrylic cover plate. Before you bolt it down, plug in the LCD connector to the interface board. It should line up nicely. If not, adjust the crease until it is just right.
Don’t forget to gently tighten down the M3 nuts on top.
Attach Sides
Attach the sides to the assembly you just built. If you didn’t tape the M3 nuts in place, you’ll need to add them first.
Now add a M3 x 16 mm bolt and tighten.  Note that if your central assembly is overtightened, you may need to loosen bolts to get the sides to slide on. Once they’ve attached, tighten them down with the remaining M3 bolts. When its finished, give everything a final tightening. Don’t overdo it though, you can crack the acrylic or splinter the wood.
Create IDC Cable
You will need a vise or crimping tool in order to make the IDC cable properly. The Gen4 electronics page has a great set of instructions for how to make IDC cables. The technique is exactly the same, but you’re using a wider ribbon cable.
Attach IDC Cable
Flip the interface board over and attach the IDC cable to the bottom as shown.
Connect To Gen4 Electronics
Open up your Thingomatic and insert the motherboard where there is a corresponding 20-pin IDC header labeled ‘Interface’. You’ll want the ribbon cable to exit the front of your bot so that you can move the interface controller around freely.
The orientation of this cable is important. Make sure the triangle on the connector lines up with the triangle on the IDC header on both the motherboard and the interface board.
If the LCD ever shows strange or garbled text at start-up, just hit the reset button on the motherboard.  This should clear things right up.
Use ItLoad the Firmware
You will need to upgrade your Motherboard firmware to version 2.8 or higher in order to use the Gen4 Interface kit.
Adjust The Contrast
The blue square trimpot on the board is a potentiometer which controls the contrast of your display. Get a small screwdriver out and adjust it to your liking. If you rotate it all the way to the left, it will be blank, and all the way to the right and it will all be black. If your screen isn’t displaying information, this may be the culprit.
Main Menu
When you first turn your machine on, the interface board will be in the Main Menu screen. From here, you can select Monitor Mode to watch the extruder and platform temperatures, Build from SD to start printing a file saved on your SD card, or Jog Mode to move the extruder head and build platform using the interface buttons.
You can navigate through the selections by pressing the Y+ and Y- buttons. To make a selection, press the Zero button. To get back to the main menu from any other menu, press the Cancel button repeatedly.
Monitor Mode
Monitor mode lets you monitor the temperature of your machine’s extruder and build platform. You can select it from the main menu, and it will come up automatically when you start printing from the SD card.
To exit Monitor Mode, press the cancel button. If a file is currently being printed from SD card, it will pop up a warning message to ask if you want to cancel the print. Select yes to cancel the print, or no to go back to Monitor Mode. (Note: to keep the interface board from interfering with machine operation, you are advised to leave the machine in Monitor Mode while printing).
Build from SD
The Build from SD menu lets you print a model directly from your SD card, no computer required! To use it, you first have to use ReplicatorG to generate an .s3g file, either by selecting ‘Upload to SD card’ with the machine attached, or by selecting ‘Build to File’, and then using your computer to copy the resulting file to the SD card.
To print your model, simply navigate to it and the press select, using the same keys as in the Main Menu. Your model will start printing immediately, and you will be taken to the Monitor Mode to watch the build status. When the print finishes, you will be taken back to the Build from SD menu to start another.
To exit the Build from SD menu, press the Cancel button.
Jog Mode
Jog Mode lets you use the interface board to position the build platform and extruder head by pressing the directional buttons. To toggle between short and long moves, press the Zero button.
To exit Jog Mode, press the Cancel button.
Hack it
Like your interface board, but have an idea about how to make it better? Feel free to hack the source! We’ve designed the menu system to make it as easy as possible to add your own portions to it. Check out the G3 Firmware on GitHub to get started.
Schematic
Source
Interface_Board_TechDrawing
Download from Thingiverse.com
The Gen4 Interface is Open Source Hardware and is licensed under the GNU GPLv3.
History
The Gen4 Interface Controller is an original design by MakerBot Industries.
GMT+8, 2026-7-24 08:22 , Processed in 0.091420 second(s), 18 queries .
