查看: 9899|回复: 1
谁能解释一下这个灵异现象???
发表于 2013-12-2 04:41:13 | 显示全部楼层 |阅读模式
32U4(Leonardo)5V工作电压  USB供电,想测试一下timer1的CTC模式,按下图公式算出1KHz对应的各寄存器参数:
代码如下
volatile unsigned long counter = 0;
volatile boolean tick = false;
volatile unsigned long time_end = 0;
unsigned long time_start = 0;
void setup(){
  delay(5000);
  TCCR1A = 0;
  TCCR1B = 0b00001001;
  TCCR1C = 0;
  OCR1A = 7999;      // 1000
  //OCR1A = 15999;    //500
  TIMSK1 = 0x02;
  sei();
  time_start = millis();
void loop(){
  if (tick)
    Serial.print("time_start = ");
    Serial.print(time_start);
    Serial.print(", ");
    Serial.print("time_end = ");
    Serial.print(time_end);
    Serial.print(", ");
    Serial.print("minus = ");
    Serial.print(time_end - time_start);
    Serial.print(", ");
    Serial.print("counter = ");
    Serial.println(counter);
    tick = false;
ISR(TIMER1_COMPA_vect){
    cli();
    if (counter++ == 500)
        time_end = millis();
        tick = true;
        TCCR1B = 0;
    sei();
运行结果如下:
time_start = 5000, time_end = 5250, minus = 250, counter = 501
这TM不是2KHz了吗?
谁能告诉我这是为什么?难道Atmel的手册写错了?
发表于 2013-12-2 15:55:48 | 显示全部楼层
没错,是你没看明白,那个频率是波的频率,波的频率要/2,就是公式里的2。
GMT+8, 2026-7-28 03:41 , Processed in 0.039926 second(s), 19 queries .
