查看: 9526|回复: 0
hd7279a的控制
发表于 2013-12-11 11:13:31 | 显示全部楼层 |阅读模式
hd7279a是一个按键和数码管驱动芯片,具体参数百度上可查。我用arduino nano控制,可以控制四位数码管显示,但是按键却总是不工作,并且KEY端子一直显示是0(表示有按键),但是读取得键值却是FF(表示没有键值),相互矛盾,希望了解的朋友提供帮助。下面是测试程序。
#define CMD_RESET 0xa4
#define CMD_TEST 0xbf
#define DECODE0 0x80
#define DECODE1 0xc8
#define CMD_READ 0x15
#define UNDECODE 0x90
#define RTL_CYCLE 0xa3
#define RTR_CYCLE 0xa2
#define RTL_UNCYL 0xa1
#define RTR_UNCYL 0xa0
#define ACTCTL 0x98
#define SEGON 0xe0
#define SEGOFF 0xc0
#define BLINKCTL 0x88
int pbIn = 1;
int key1=0;
int dat=10;
int key=3;
int cs=12;
int clk=11;
int num0=9;
  pinMode(dat,OUTPUT);
     pinMode(cs,OUTPUT);
     pinMode(clk,OUTPUT);
    pinMode(key,OUTPUT);
      send_byte(CMD_TEST);
      Serial.println(pbIn);
  delay(1000);
send_byte(CMD_RESET);
   write7279(DECODE1,key);
  write7279(DECODE1+1,key1);
   write7279(DECODE1+2,pbIn);
    write7279(DECODE1+3,num0);
pbIn=digitalRead(key);
    Serial.println(key1);
key1=read7279(CMD_READ);
  delay(1000);
void write7279(unsigned char cmd, unsigned char dta)
        send_byte (cmd);
        send_byte (dta);
unsigned char read7279(unsigned char command)
        send_byte(command);
        return(receive_byte());
void send_byte(        unsigned char out_byte)
        unsigned char i;
        digitalWrite(cs, LOW);
        delayMicroseconds(50);
        for (i=0;i<8;i++)
                if (out_byte&0x80)
                digitalWrite(dat, HIGH);
                        digitalWrite(dat, LOW);
                digitalWrite(clk, HIGH);
                delayMicroseconds(1);
                digitalWrite(clk, LOW);
                out_byte=out_byte*2;
unsigned char receive_byte(void)
        unsigned char i, in_byte;
        for (i=0;i<8;i++)
                in_byte=in_byte*2;
                if (digitalRead(dat))
                        in_byte=in_byte|0x01;
        return (in_byte);
GMT+8, 2026-7-28 14:20 , Processed in 0.032281 second(s), 17 queries .
