查看: 9500|回复: 0
如何提高查找速度?
发表于 2013-12-31 23:36:26 | 显示全部楼层 |阅读模式
       在学习如下WebServerPost代码示例时,发现TextFinder.h 中getValue()和findUntil()执行效率很低,运行到此处时要耗费10s钟,有没有好办法提高执行效率?
*WebServerPost sketch
#include <SPI.h>
#include <Ethernet.h>
#include <TextFinder.h>
byte mac[] = {0xDE,0xAD,0xBE,0xEF,0xFE,0xED};
byte ip[] = {192,168,1,177};
char buffer[8];
EthernetServer server(80);
void setup(){
  Ethernet.begin(mac,ip);
  delay(3000);
  Serial.println("Ready");
void loop(){
  EthernetClient client = server.available();
  if(client){
    TextFinder finder(client);
    int  type = 0;
    while(client.connected()){
       if(client.available()){
         //GET,POST,or HEAD
         if(finder.getString("","/",buffer,sizeof(buffer))){
             if(strcmp(buffer,"POST ")==0){
               finder.find("\n\r");
                  int startTime = millis(); //
               while(finder.findUntil("pinD","\n\r")){
                  int pin = finder.getValue();
                  int val = finder.getValue();
                 Serial.println(millis()-startTime);  //上述耗费10s,有何好办法效率更高点
                  pinMode(pin,OUTPUT);
                  digitalWrite(pin,val);
             sendHeader(client,"Post example");
             client.println("<h2>点击按钮分别关闭和电灯 pin8 led</h2>");
             client.print("<form action = '/' method = 'POST'><P><input type = 'hidden' name = 'pinD8'");
             client.println(" value='0'><input type='submit' value = 'off' /></form>");
             client.print("<form action = '/' method = 'POST'><p><input type = 'hidden' name = 'pinD8'");
             client.print(" value='1'><input type= 'submit' value = 'On'/></form>");
             client.println("</body></html>");
             client.stop();
    //give the web browser time to receive the data
    delay(1);
    client.stop();
void sendHeader(EthernetClient client,char *title){
   //send a standard http response header
   client.println("HTTP/1.1 200 OK");
   client.println("Content-Type: text/html");
   client.println();
   client.print("<html><head><title>");
   client.print(title);
   client.println("</title><body>");
GMT+8, 2026-7-28 11:12 , Processed in 0.032483 second(s), 17 queries .
