查看: 9455|回复: 8
请教一下MPU6050的使用问题,谢谢
发表于 2014-1-14 19:38:09 | 显示全部楼层 |阅读模式
Arduino Uno + MPU6050三轴,Arduino测试时全部是0,波特率38400 COM3我的是3,出来都是0刷新挺快的,是不是6050坏了?谢谢!
 楼主| 发表于 2014-1-14 19:39:40 | 显示全部楼层
我用的是Arduino1.01
 楼主| 发表于 2014-1-14 19:48:12 | 显示全部楼层
这个代码!
// I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class
// 10/7/2011 by Jeff Rowberg <[email protected]>
// Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// Changelog:
//     2011-10-07 - initial release
I2Cdev device library code is placed under the MIT license
Copyright (c) 2011 Jeff Rowberg
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include "Wire.h"
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050.h"
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define LED_PIN 13
bool blinkState = false;
    // join I2C bus (I2Cdev library doesn't do this automatically)
    Wire.begin();
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    Serial.begin(38400);
    // initialize device
    Serial.println("Initializing I2C devices...");
    accelgyro.initialize();
    // verify connection
    // configure Arduino LED for
    pinMode(LED_PIN, OUTPUT);
    // read raw accel/gyro measurements from device
    // these methods (and a few others) are also available
    //accelgyro.getAcceleration(&ax, &ay, &az);
    //accelgyro.getRotation(&gx, &gy, &gz);
    // display tab-separated accel/gyro x/y/z values
    Serial.print("a/g:\t");
    Serial.print(ax); Serial.print("\t");
    Serial.print(ay); Serial.print("\t");
    Serial.print(az); Serial.print("\t");
    Serial.print(gx); Serial.print("\t");
    Serial.print(gy); Serial.print("\t");
    Serial.println(gz);
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
发表于 2014-1-14 20:08:43 | 显示全部楼层
uno 要接中断,好像是int对应d2
 楼主| 发表于 2014-1-14 20:43:00 | 显示全部楼层
wunanyx 发表于 2014-1-14 20:08
uno 要接中断,好像是int对应d2
谢谢老师回复!!d2你指的是?
 楼主| 发表于 2014-1-14 22:09:41 | 显示全部楼层
不行啊!
 楼主| 发表于 2014-1-15 10:03:09 | 显示全部楼层
好啦!
把排针焊好,又仔细看了一下6050,突然发现A4\A5接反了,这个折腾啊!
 楼主| 发表于 2014-1-15 10:05:52 | 显示全部楼层
初学的菜鸟们看了引以为戒哦!!!
发表于 2014-1-20 09:13:01 | 显示全部楼层
shuaigou 发表于 2014-1-15 10:03
好啦!
好吧,这就算解决了:)
GMT+8, 2026-7-28 11:51 , Processed in 0.074186 second(s), 18 queries .
