查看: 11376|回复: 3
enc28j60网络应用问题求解
发表于 2014-1-16 09:48:40 | 显示全部楼层 |阅读模式
最近试验了enc28j60网络模块,上传单个数据是可以的,但隔断时间发5个数据串口显示会乱码?求高手指点。
代码如下:
#include <EtherCard.h>
static byte mymac[] = {0xe8,0x9a,0x8f,0xcf,0x8a,0xcf};
byte Ethernet::buffer[400];
char buf[50];
static long timer;
uint8_t lwCount=0;
float temp=0;
#define REQUEST_RATE 10000 // milliseconds
char website[] PROGMEM = "www.lewei50.com";
char urlBuf[] PROGMEM = "/api/V1/gateway/UpdateSensors/01";
char apiKey[] PROGMEM = "userkey:***********************";
char *lwSensor[5]={"T1", "T2", "T3", "T4", "T5"};
static void my_result_cb (byte status, word off, word len) {
  Serial.print("<<< reply ");
  Serial.print(millis() - timer);
  Serial.println(" ms");
  Serial.println((const char*) Ethernet::buffer + off);
void setup () {
  Serial.println("\n[Lewei50.com]");
  if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
    Serial.println( "Failed to access Ethernet controller");
   Serial.println("Ethernet controller initialized");
  if (!ether.dhcpSetup())
    Serial.println("Failed to get configuration from DHCP");
    Serial.println("DHCP configuration done");
  ether.printIp("IP Address:\t", ether.myip);
  ether.printIp("Netmask:\t", ether.mymask); //子掩码
  ether.printIp("Gateway:\t", ether.gwip);//网关
    if (!ether.dnsLookup(website))
    Serial.println("DNS failed");
  ether.printIp("Server: ", ether.hisip);
  timer = - REQUEST_RATE; // start timing out right away
void loop () {
  ether.packetLoop(ether.packetReceive());
  if (millis() > timer + REQUEST_RATE)
    timer = millis();
     e_send();
void e_send(void)
Serial.println("\n>>> send");
    temp=temp+0.2;
    if(temp>2000)
    temp=0;
  uint8_t  whole, fract;
  whole=(int)(temp*10.0)/10;
  fract = (int)(temp*10.0) % 10;
  sprintf(buf,"[{\"Name\":\"%s\",\"Value\":\"%d.%d\"}]",lwSensor[lwCount], whole,fract);
    Serial.println(buf);
    ether.dnsLookup(website);
    ether.httpPost (urlBuf, website, apiKey, buf, my_result_cb);
         lwCount++;
  if(lwCount>5)
  lwCount=0;
   Serial.println(lwCount);
发表于 2014-1-16 10:24:45 | 显示全部楼层
乱码是什么样子的?截图看一下
 楼主| 发表于 2014-1-16 11:06:45 | 显示全部楼层
lwcount第一次从0-4正常,再往下就不对了:
>>> send
[{"Name":"T5","Value":"1.0"}]
Server: 42.121.254.11
4
<<< reply 170 ms
HTTP/1.1 200 OK
Date: Thu, 16 Jan 2014 03:00:36 GMT
Content-Type: application/json; charset=utf-8
Content-Length: 44
Connection: close
Cache-Control: private
Set-Cookie: SERVERID=a4a5b2bbca16d8c8b2ba6d5b6e55f36e|1389841236|1389841236ath=/
{"Successful":true,"Message":"Successful. "}
>>> send
[{"Name":"ation/json; charset=utf-8
Content-Length: 44
Connection: close
Set-Cookie: SERVERID=a4a5b2bbca16d8c8b2ba6d5b6e55f36e|1389841236|1389841236ath=ˉ
&#146;{"Sccessful":true,"Message":"Successful. "}","Value":"1.2"}]
Server: 0.0.0.0
104
红色是第二次串口输出 不对了。
 楼主| 发表于 2014-1-16 11:10:07 | 显示全部楼层
网络上显示value是0.2  0.4  0.6  0.8  1.0  就不在显示了,求解呀?
GMT+8, 2026-7-28 02:36 , Processed in 0.041142 second(s), 18 queries .
