查看: 10003|回复: 1
局域网网页控制led开关问题、懂得大神给解释一下代码意思。谢谢
发表于 2014-2-28 21:41:26 | 显示全部楼层 |阅读模式
新手刚接触arduino和w5100,想实现网页局域网控制led开关,于是在网上找了一个帖子《利用arduino+w5100 把网页上的颜色输出到RGB LED上显示 》(http://www.geek-workshop.com/for ... thread&tid=8511)。我想实现最终的是在网页文本框里,输入1,灯开;输入2,灯关。于是我自己改了一下。能力有限改着改着不会改了。
1、希望大神给我不懂得代码一点点指点(代码面有//的都不怎么明白,如果没时间那就帮我解释一下//后面有数字的吧)。
2、如果我想实现最终的是在网页文本框里,输入1,灯开;输入2,灯关。该怎么改?希望大神给修改一下
代码如下:
#include <SPI.h>
#include <Ethernet.h>
int  red = 9;       //设置输出端口
int blue = 6;
int green = 5;
int i ;
int red_color,asc;//定义各颜色的PWM值参数
String POST = "";
String SET = "";
////网页上的颜色参数,每六字母为一种颜色,每个网页上有6个颜色,也就是36个字母
char color[]={"ff000000ff000000ffffff0000ffffffffff"
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
  //服务端IP地址
IPAddress ip(192,168,1,178);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// Open serial communications and wait for port to open:
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  //设置端口为输出
  pinMode(red, OUTPUT);
  // listen for incoming clients
  EthernetClient client = server.available();                                                 //
  if (client) {        //
    Serial.println("new client");        //
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;                                                     //
    while (client.connected()) {                                                               //
      if (client.available()) {        //
        char c = client.read();                                                               //什么意思? c是改变的吗?接受的值是什么?
        Serial.write(c);        //什么意思?
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank){
          // it is after the double cr-lf that the variables are
          // read another line!
          String POST = "";        //POST是干什么的?
         // int p = 1;
          while(client.available())                                                             //
            // save the variables somewhere
            POST += c;        //
          // send a standard http response header
          //打印输出网页代码
         client.println("<html><head><title>Lamaq Color palette</title>"
                        "<style>*{font-family:Arial;}body{background-color:#f2f2f2;}h1{color:#222;}</style>"
                        "<body><div style='text-align:center;'>"
                        "<div>Color palette"
                        "<table width='30%'  align='center'>"
                        "<tr><td>"
                        "<table width='100%' height='100'  cellspacing='1'><tbody><tr>");
         client.println("</tr></tbody></table>");
         client.println("<table  width='100%'  id='led'>");
         client.print("<tbody><tr>");
         client.print("<form method='post' id='ledform'>Led color:");
         client.print("<input type='text' name='led' id='led' value='");
         /****网页表单采用POST方式传送到服务端,
         服务端从POST参数中的第7至第12的字符中得到鼠标点击的颜色值,
         并转换成ASCII码值,码值减去87或46后可得到实际数值,通过计算得到RGB的PWM值****/
           for (int j=7; j<13; j++){
                      i = int(POST[j]);
                       if(i > 96 && i < 103){
                           asc = 87;
                         }else if(i > 47 && i < 58){asc = 48;
                           }else{client.print("#ff0000");
                                 break;}
                          if(j==7){red_color = ((i-asc)*16);}
                          if(j==8){red_color += (i-asc);
                          client.print("#00ff00");}
                       client.print("'>");
         client.println("<input type='submit' value='Submit'>"
                        "</form></tr></tbody></table></td></tr></table></div></div></body></html>");
        if (c == '\n') {        //
          // you're starting a new line
        else if (c != '\r') {        //
          // you've gotten a character on the current line
          currentLineIsBlank = false;        //
    // give the web browser time to receive the data
    delay(1);        //
    // close the connection:
   client.stop();        //
    Serial.println("client disonnected");
   // i=1;
    analogWrite(red, red_color);
发表于 2014-2-28 22:47:24 | 显示全部楼层
这问题更多的是涉及了WEB服务了。
推荐看这个教程,硬件可能和你的不一样。http://www.geek-workshop.com/thread-2257-1-1.html
GMT+8, 2026-7-28 19:43 , Processed in 0.035350 second(s), 18 queries .
