查看: 12738|回复: 6
一头雾水的总线
发表于 2014-3-3 03:34:13 | 显示全部楼层 |阅读模式
冥冥之中感觉总线是个好东西,可以控制很多件东西。可以总攻,也可分散作战,大局全由总司令控制。点到谁,谁干活。
所有程序都是考培教程里的例子,大部分语句还算能搞明白。但是发现一个设备的总线号。这个号码是设备自身就带的?还是能后来由系统分配的?好似很多例子文件都是直接给了一个0X**的编号。刚才找到一个搜索系统设备总线号码的程序,于是就插了多个总线设备在上门,结果惊奇的发现,2设备号码是一样的。  一个陀螺仪0x53,又接上一个256k的eeprom,结果那东西有8个号码,从0x50~0x57,其中0x53是和陀螺仪重复的,这个号码可以自己修改吗?
论坛教程里也有搜索i2c号设备的程序好像是1.0的,现在1.5的变化比较大,也不会修改。结果看到个1.5可用的还是不错的。
  1. // --------------------------------------
  2. // i2c_scanner
  3. //
  4. // Version 1
  5. //    This program (or code that looks like it)
  6. //    can be found in many places.
  7. //    For example on the Arduino.cc forum.
  8. //    The original author is not know.
  9. // Version 2, Juni 2012, Using Arduino 1.0.1
  10. //     Adapted to be as simple as possible by Arduino.cc user Krodal
  11. // Version 3, Feb 26  2013
  12. //    V3 by louarnold
  13. // Version 4, March 3, 2013, Using Arduino 1.0.3
  14. //    by Arduino.cc user Krodal.
  15. //    Changes by louarnold removed.
  16. //    Scanning addresses changed from 0...127 to 1...119,
  17. //    according to the i2c scanner by Nick Gammon
  18. //    [url]http://www.gammon.com.au/forum/?id=10896[/url]
  19. // Version 5, March 28, 2013
  20. //    As version 4, but address scans now to 127.
  21. //    A sensor seems to use address 120.
  22. //
  23. //
  24. // This sketch tests the standard 7-bit addresses
  25. // Devices with higher bit address might not be seen properly.
  26. //
  27. #include <Wire.h>
  28. void setup()
  29. {
  30.   Wire.begin();
  31.   Serial.begin(9600);
  32.   Serial.println("\nI2C Scanner");
  33. }
  34. void loop()
  35. {
  36.   byte error, address;
  37.   int nDevices;
  38.   Serial.println("Scanning...");
  39.   nDevices = 0;
  40.   for(address = 1; address < 127; address++ )
  41.   {
  42.     // The i2c_scanner uses the return value of
  43.     // the Write.endTransmisstion to see if
  44.     // a device did acknowledge to the address.
  45.     Wire.beginTransmission(address);
  46.     error = Wire.endTransmission();
  47.     if (error == 0)
  48.     {
  49.       Serial.print("I2C device found at address 0x");
  50.       if (address<16)
  51.         Serial.print("0");
  52.       Serial.print(address,HEX);
  53.       Serial.println("  !");
  54.       nDevices++;
  55.     }
  56.     else if (error==4)
  57.     {
  58.       Serial.print("Unknow error at address 0x");
  59.       if (address<16)
  60.         Serial.print("0");
  61.       Serial.println(address,HEX);
  62.     }
  63.   }
  64.   if (nDevices == 0)
  65.     Serial.println("No I2C devices found\n");
  66.   else
  67.     Serial.println("done\n");
  68.   delay(5000);           // wait 5 seconds for next scan
  69. }
发表于 2014-3-3 08:34:40 | 显示全部楼层
这个是模块本身自己带的,你可以理解为当通讯的时候,总线的master会在总线上问,谁是 0xAB? 如果有就
有人回复,我是。然后就可以通讯。否则 master 就会出现超时,知道这个地址没有人用。
模块自己的地址一般在设计的时候会预留更改方式,比如:通过跳线可以在几个地址内选择。还有的是内部
firmware 决定的。
想要了解更多可以去K一下 I2C Spec
发表于 2014-3-3 13:10:26 | 显示全部楼层
很多I2C设备都预置了几个总线地址,并提供修改自己总线地址的方法。大多是将某1-2个脚置高/低电平。具体需要参考芯片的datasheet了。
 楼主| 发表于 2014-3-3 13:44:41 | 显示全部楼层
isilcala 发表于 2014-3-3 13:10
很多I2C设备都预置了几个总线地址,并提供修改自己总线地址的方法。大多是将某1-2个脚置高/低电平。具体需要 ...
就这2个东西,好似也没找到能改地址的地方。呵呵。有点蒙
发表于 2014-3-3 16:11:57 | 显示全部楼层
查一下datasheet吧
发表于 2014-3-3 20:15:39 | 显示全部楼层
问卖家一下  taobao上买的吧?
发表于 2014-3-4 08:43:54 | 显示全部楼层
zoologist 发表于 2014-3-3 20:15
问卖家一下  taobao上买的吧?
把卖家的资料贴上来吧?一般不提供技术支持但是资料肯定有啊
GMT+8, 2026-7-28 17:58 , Processed in 0.081277 second(s), 20 queries .
