楼主 |
发表于 2014-3-5 22:07:02
显示全部楼层
- #include <SPI.h>
- #include <Ethernet.h>
- int red = 9; //设置输出端口
- int i ;
- int red_color,asc;//定义各颜色的PWM值参数
- String POST = "";
- String SET = "";
- // Enter a MAC address and IP address for your controller below.
- // The IP address will be dependent on your local network:
- byte mac[] = {
- 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
- //服务端IP地址
- IPAddress ip(192,168,1,178);
- // Initialize the Ethernet server library
- // with the IP address and port you want to use
- // (port 80 is default for HTTP):
- EthernetServer server(80);
- void setup() {
- // Open serial communications and wait for port to open:
- Serial.begin(9600);
- Ethernet.begin(mac, ip);
- server.begin();
- pinMode(red, OUTPUT);
- Serial.print("server is at ");
- Serial.println(Ethernet.localIP());
- //设置端口为输出
- void loop() {
- // listen for incoming clients
- EthernetClient client = server.available();
- if (client) {
- Serial.println("new client");
- // an http request ends with a blank line-----------
- boolean currentLineIsBlank = true;
- while (client.connected()) {
- if (client.available()) {
- char c = client.read();
- Serial.write(c);
- // if you've gotten to the end of the line (received a newline
- // character) and the line is blank, the http request has ended,
- // so you can send a reply
- if (c == '\n' && currentLineIsBlank){
- // it is after the double cr-lf that the variables are
- // read another line!
- String POST = "";
- // int p = 1;
- while(client.available())
- c = client.read();
- // save the variables somewhere
- POST += c;
- // send a standard http response header
- //打印输出网页代码
- client.println("<html><head><title>Lamaq Color palette</title>"
- "<style>*{font-family:Arial;}body{background-color:#f2f2f2;}h1{color:#222;}</style>"
- "<body><div style='text-align:center;'>"
- "<div>Color palette"
- "<table width='30%' align='center'>"
- "<tr><td>"
- "<table width='100%' height='100' cellspacing='1'><tbody><tr>");
- client.println("</tr></tbody></table>");
- client.println("<table width='100%' id='led'>");
- client.print("<tbody><tr>");
- client.print("<form method='post' id='ledform'>Led color:");
- client.print("<input type='text' name='led' id='led' value='");
- // for (int j=0; j<10; j++){
- i = int(POST[4]);
- if(i==49){red_color=240;}
- if(i==48){red_color=0; }
- // i = int(POST[5]);
- // {red_color=240;client.print(POST[5]);}
- client.print("'>");
- client.println("<input type='submit' value='Submit'>"
- "</form></tr></tbody></table></td></tr></table></div></div></body></html>");
- break;
- if (c == '\n') {
- // you're starting a new line
- currentLineIsBlank = true;
- else if (c != '\r') {
- // you've gotten a character on the current line
- currentLineIsBlank = false;
- // give the web browser time to receive the data
- delay(1);
- // close the connection:
- client.stop();
- Serial.println("client disonnected");
- // i=1;
- analogWrite(red, red_color);
复制代码 |
