[ 本帖最后由 oifgjhk 于 2014-3-5 23:09 编辑 ]\n\n[ 本帖最后由 oifgjhk 于 2014-3-5 23:08 编辑 ]\n\n请大神帮忙看看,我这样理解卡尔曼滤波对不对...新手,还请见谅
[pre lang="c++" line="1"]#ifndef KALMAN_H
#define KALMAN_H
using namespace std;
class kalman;
class MPU_measure{
friend class kalman;
public:
MPU_measure(float f1, float f2) :angle_m(f1), gyro_m(f2){}
MPU_measure() = default;
private:
float angle_m;//加速度计测得的角度
float gyro_m;//陀螺仪测得的角度
class kalman:MPU_measure{
public:
kalman(float f1, float f2) :angle(0), angle_dot(0), q_bias(0), angle_err(0), Kg_0(0), Kg_1(0), MPU_measure(f1,f2){
P[0][0] = 1;
P[0][1] = 0;
P[1][0] = 0;
P[1][1] = 1;
P_process[0] = 0;
P_process[1] = 0;
P_process[2] = 0;
P_process[3] = 0;
float get_value(){
return angle;
//向前推算状态变量(先验估计)
void froward_forecast();
//向前推算误差协方差
void P_forecast();
//计算kalman增益
void calculate_Kg();
//后验状态估计
void backward_forecast();
//更新误差协方差
void P_update();
private:
//kalman 滤波后得到的角度
float angle, angle_dot;
//固定值: 角度过程噪声, 陀螺仪过程噪声, 测量噪声, 时间微分
const float Q_angle = 0.001, Q_gyro = 0.003, R_angle = 0.5, dt = 0.0001;
//协方差计算过程中的Q 过程噪声协方差
float P_process[4];
//协方差: ( P[0][0]:angle 协方差) (P[0][1])(P[1][0]:bias 协方差)(P[1][1]:陀螺仪 协方差)
float P[2][2];
// 偏差 观测过程的革新
float q_bias, angle_err;
// angle kalman增益 ,bias kalman增益
float Kg_0, Kg_1;
const char A = 1, B = 1, H = 1;
//公式中^表示估计,-表示先验
void kalman::froward_forecast()
//公式 X^-(k)=AX^(k-1)+BU(k-1)+w(k)
angle = A*angle + (gyro_m - q_bias)*dt;//先验估计
void kalman:: P_forecast()
//公式P-(k)=AP(k-1)At+Q
P_process[0] = Q_angle - P[0][1] - P[1][0];
P_process[1] = -P[1][1];
P_process[2] = -P[1][1];
P_process[3] = Q_gyro;
P[0][0] = A*P[0][0]*A + P_process[0] * dt;
P[0][1] = A*P[0][1]*A + P_process[1] * dt;
P[1][0] = A*P[1][0]*A + P_process[2] * dt;
P[1][1] = A*P[1][1]*A + P_process[3] * dt;
void kalman::calculate_Kg()
//公式K(k)=(P-(k)Ht)/(HP-(k)Ht+R)
Kg_0 = (P[0][0] * H) / ((H*P[0][0] * H) + R_angle);
Kg_1 = (P[1][0] * H) / ((H*P[0][0] * H) + R_angle);
void kalman::backward_forecast()
//公式X^(k)=X^-(k)+K(k)(Z(k)-HX^-(k))
angle = angle + Kg_0*(angle_m - H*angle);
q_bias = q_bias + Kg_1*(angle_m - H*angle);
void kalman:: P_update()
//公式P(k)=(1-K(k)H)P-(k)
P[0][0] = P[0][0] - Kg_0*H*P[0][0];
P[0][1] = P[0][1] - Kg_0*H*P[0][1];
P[1][0] = P[1][0] - Kg_1*H*P[0][0];
P[1][1] = P[1][1] - Kg_1*H*P[0][1];
#endif[/code] |
