查看: 21376|回复: 7
Arduino Rx 读取数值问题 求大家帮忙
发表于 2014-3-12 06:02:18 | 显示全部楼层 |阅读模式
大家好,小女子是个新手。
请问我现在想用Arduino Uno Rx 读取以下数值要怎么做?
我已经将Arduino 第一板的Tx连接到第二块板的Rx
我用Serial.println(y)在第一块板上输出int y的值, 却没办法在第二块板上用Serial.read(y)读出相等数值
请求各位大神帮助!!!!!!
发表于 2014-3-12 08:37:28 | 显示全部楼层
在具体一点,画个图吧,要不然不知道你想干嘛
发表于 2014-3-12 08:40:03 | 显示全部楼层
正如1楼所述
需要2个条件:
1.你的源码
2.你的接线方式(你这个仅仅是跳连RX和TX么)
 楼主| 发表于 2014-3-12 21:45:47 | 显示全部楼层
darkorigin 发表于 2014-3-12 08:40
正如1楼所述
需要2个条件:
1.你的源码
1.源码
#include <Wire.h>
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
int L3G4200D_Address = 105; //I2C address of the L3G4200D
int x;
int y;
int z;
void setup(){
  Wire.begin();
  setupL3G4200D(2000); // Configure L3G4200  - 250, 500 or 2000 deg/sec
  delay(1500); //wait for the sensor to be ready
void loop(){
   getGyroValues();  // This will update x, y, and z with new values
   Serial.println(y);
  delay(100); //Just here to slow down the serial to make it more readable
void getGyroValues(){
  byte xMSB = readRegister(L3G4200D_Address, 0x29);
  byte xLSB = readRegister(L3G4200D_Address, 0x28);
  x = ((xMSB << 8)| xLSB);
  byte yMSB = readRegister(L3G4200D_Address, 0x2B);
  byte yLSB = readRegister(L3G4200D_Address, 0x2A);
  y = ((yMSB << 8)| yLSB);
  byte zMSB = readRegister(L3G4200D_Address, 0x2D);
  byte zLSB = readRegister(L3G4200D_Address, 0x2C);
  z = ((zMSB << 8)| zLSB);
int setupL3G4200D(int scale){
  writeRegister(L3G4200D_Address, CTRL_REG1, 0b00001111);
  writeRegister(L3G4200D_Address, CTRL_REG2, 0b00000000);
  writeRegister(L3G4200D_Address, CTRL_REG3, 0b00001000);
  if(scale == 250){
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00000000);
  }else if(scale == 500){
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00010000);
  }else{
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00110000);
  writeRegister(L3G4200D_Address, CTRL_REG5, 0b00000000);
void writeRegister(int deviceAddress, byte address, byte val) {
    Wire.beginTransmission(deviceAddress); // start transmission to device
    Wire.write(address);       // send register address
    Wire.write(val);         // send value to write
    Wire.endTransmission();     // end transmission
int readRegister(int deviceAddress, byte address){
    int v;
    Wire.write(address); // register to read
    Wire.requestFrom(deviceAddress, 1); // read a byte
    while(!Wire.available()) {
        // waiting
    v = Wire.read();
    return v;
2.我用两条线交叉连接了两块板的RX和TX
 楼主| 发表于 2014-3-12 21:48:14 | 显示全部楼层
我用第一个板传送陀螺仪上的Y轴数值源码如上,想用第二块板读取相应的y轴数值从而控制伺服的角度。只是第二块板怎么都读不如图上一致的相同数值
 楼主| 发表于 2014-3-12 21:57:35 | 显示全部楼层
第二块板的源码。。。。 可是接收的数据却是完全不同的。。。
#include <Servo.h>
int y;
int currentAngle1=90;
Servo myservo1;  //servo1 for y-axis
void setup(){
  myservo1.attach(10); //servo for y-axis
void loop(){
   y=Serial.read();
   Serial.println(Serial.read());
   delay(100);
if(y>=200||y<=-200){
   y/=130; //set the y value divides by time to reach the angle
   currentAngle1+=y;
   if(currentAngle1>180)
   currentAngle1=180;
     else if(currentAngle1<0)
     currentAngle1=0;
   myservo1.write(currentAngle1);
____
54
10
53
10
54
10
53
10
55
10
56
10
53
10
54
10
54
10
56
10
发表于 2014-3-13 09:06:04 | 显示全部楼层
个人感觉不像是读取的问题,有可能是第二块板子串口冲突了?
建议你实验第一块板子发固定的数值,第二个板子直接接收并且打印出来
或者直接试试软串口来接受
发表于 2014-3-13 09:15:22 | 显示全部楼层
你这个出来的值似乎很规律啊,都是53-57之间的值加一个 10
根据ASCII码表 貌似是字符5  6 7 8等的值  10是TAB的ASCII值。
GMT+8, 2026-7-28 20:36 , Processed in 0.082333 second(s), 21 queries .
