查看: 9740|回复: 0
求解 web控制uno+opnwtr+w5100 UNO收不到数据问题
发表于 2014-3-12 21:30:48 | 显示全部楼层 |阅读模式
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 177);
int ledPin7 = 7;
char cc = ' ';
char ccc = ' ';
EthernetServer server(80);
   while (!Serial) {
  pinMode(ledPin7, OUTPUT);
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  EthernetClient client = server.available();
  if (client) {
    Serial.println("new client");
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
       //   client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            if (analogChannel == 1)
               int A1 = analogRead(analogChannel);
               int guangqiang = A1;
               client.print(guangqiang);
             client.print(":");
             if (analogChannel == 2)
              int A2 = analogRead(analogChannel);
              int wendu= (A2*0.0048828125*100);
              client.print(wendu);
          client.println("</html>");
      //  byte c = client.read();
        if(c == 'O' && cc == '=')
                if(ccc == 'X')
                 digitalWrite(7,HIGH);
                 else if(ccc == 'Y')
                 digitalWrite(7,LOW);
          ccc = cc;
          cc = c;
        if (c == '\n') {
        else if (c != '\r') {
          currentLineIsBlank = false;
    delay(1);
    client.stop();
    Serial.println("client disonnected");
下位机代码   web里能收到返回的温度值,但是web给UNO发指令 uno无反应。求解~求大神。。。
GMT+8, 2026-7-28 23:02 , Processed in 0.056154 second(s), 17 queries .
