查看: 8722|回复: 8
【求教】12864 问题,垂直向右移
发表于 2014-3-18 16:09:15 | 显示全部楼层 |阅读模式
目前LCD可以点亮。就是水平方向向右移了2个像素。我不知道怎么改。
代码如下 蛮长{:soso_e143:}
Modified for use with Camera Axe with written permission from Oliver Kraus.
Maurice Ribble - 9/4/2010
Now shared under Creative Commons Attribution 3.0 License
(http://creativecommons.org/licenses/by-sa/3.0/)
dogm128.c
(c) 2010 Oliver Kraus ([email protected])
graphic functions for the dogm128 graphics module
with ST7565R controller from electronic assembly
optimized c-code for avr-gcc
This file is part of the dogm128 Arduino library.
The dogm128 Arduino library is free software: you can redistribute it and/or modify
it under the terms of the Lesser GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
The dogm128 Arduino library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Lesser GNU General Public License for more details.
You should have received a copy of the Lesser GNU General Public License
along with dogm128. If not, see <http://www.gnu.org/licenses/>.
size = 0:
size = 1:
ST7565R SPI interface
ST7565R reads data with rising edge of the clock signal (SCL)
--> CPHA = 0 and CPOL = 0
ST7565R reads MSB first
--> DORD = 0
/usr/lib/avr/include/avr/pgmspace.h
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "dogm128.h"
#include <avr/interrupt.h>
#include <avr/io.h>
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "wiring.h"
#endif
#ifdef PROGMEM
#define dog_pgm_read_w(adr) pgm_read_word_near(adr)
#define dog_pgm_read(adr) pgm_read_byte_near(adr)
#else
#define dog_pgm_read_w(adr) (*(const int16_t *)(adr))
#define dog_pgm_read(adr) (*(const char *)(adr))
#endif
#define DOG_WIDTH 128
#define DOG_HEIGHT 64
#define DOG_PAGE_WIDTH 128
#define DOG_PAGE_CNT 8
#define DOG_PAGE_HEIGHT 8
unsigned char dog_page_buffer[DOG_PAGE_WIDTH];
uint8_t dog_curr_page = 0;/* 0...DOG_PAGE_CNT-1 */
uint8_t dog_min_y = 0;
uint8_t dog_max_y = DOG_PAGE_HEIGHT-1;
SPI subsystem for Arduino
Pins 15 to 19 (ATMEGA8) or 10 to 13 (Arduino) are used.
unsigned char dog_spi_pin_a0 = PIN_A0_DEFAULT;
void dog_init_spi(void)
pinMode(PIN_SCK, OUTPUT);
pinMode(PIN_MOSI, OUTPUT);
//pinMode(PIN_MISO, INPUT);
pinMode(PIN_SS, OUTPUT);
pinMode(dog_spi_pin_a0, OUTPUT);
SPR1 SPR0
00fclk/4
01fclk/16
10fclk/64
11fclk/128
SPCR = 0;
SPCR = (1<<SPE) | (1<<MSTR)|(0<<SPR1)|(0<<SPR0)|(0<<CPOL)|(0<<CPHA);
unsigned char x;
x = SPSR;
x= SPDR;
unsigned char dog_spi_out(unsigned char data)
/* unsigned char x = 100; */
/* send data */
SPDR = data;
/* wait for transmission */
while (!(SPSR & (1<<SPIF)))
/* clear the SPIF flag by reading SPDR */
return SPDR;
void dog_spi_enable_client(void)
digitalWrite(PIN_SS, LOW);
void dog_spi_disable_client(void)
digitalWrite(PIN_SS, HIGH);
void dog_cmd_mode(void)
digitalWrite(dog_spi_pin_a0, LOW);
void dog_data_mode(void)
digitalWrite(dog_spi_pin_a0, HIGH);
void dog_delay(unsigned short val)
delay(val);
void dog_init_display(void)
dog_delay(10);
dog_spi_disable_client();/* force reset of the spi subsystem of the ST7565R */
dog_delay(10);
dog_spi_enable_client();
dog_delay(10);
dog_cmd_mode();
/* mostly taken from the EA dogm description */
dog_spi_out(0x060);/* set display start line to 0 */
dog_spi_out(0x0a1);/* ADC set to reverse */
dog_spi_out(0x0c0);/* common output mode */
dog_spi_out(0x0a6);/* display normal, bit val 0: LCD pixel off. */
dog_spi_out(0x0a2);/* LCD bias 1/9 */
dog_spi_out(0x02f);/* all power control circuits on */
dog_spi_out(0x0f8);/* set booster ratio to */
dog_spi_out(0x000);/* 4x */
dog_spi_out(0x027);/* set V0 voltage resistor ratio to large */
dog_spi_out(0x023);/* contrast value, EA default: 0x016 */
dog_spi_out(0x081); /* set contrast */
//dog_spi_out(0x081);
dog_spi_out(0x0ac);/* indicator */
dog_spi_out(0x000);/* disable */
dog_spi_out(0x0af);/* display on */
dog_spi_out(0x0a5);/* display all points */
dog_delay(300);
dog_spi_out(0x0a4);/* normal display */
dog_delay(300);
void dog_init(unsigned short pin_a0)
dog_delay(50);/* initial delay */
dog_spi_pin_a0 = pin_a0;
dog_delay(10);
dog_init_spi();
dog_init_display();
void dog_set_contrast(uint8_t val)
val &= 63;
dog_cmd_mode();
dog_spi_out(0x081);/* set contrast */
dog_spi_out(val);/* contrast value */
dog_data_mode();
void dog_set_inverse(uint8_t val)
val &= 1;
val |= 0x0a6;/* invert pixel mode */
dog_cmd_mode();
dog_spi_out(val);
dog_data_mode();
void dog_transfer_page(void)
signed char idx;
/* enable and reset com interface of the ST7565R */
/* set write position */
dog_cmd_mode();
dog_spi_out(0x0b0 | dog_curr_page );/* select current page */
dog_spi_out(0x010 );/* set upper 4 bit of the col adr to 0 */
dog_spi_out(0x001 );/* set lower 4 bit of the col adr to 0 */
/* send a complete page */
dog_data_mode();
idx = 127;
while( idx >= 0 )
dog_spi_out(dog_page_buffer[idx]);
idx--;
/* disable com interface of the ST7565R */
/* page buffer functions */
void dog_ClearPage(void)
uint8_t i;
for( i = 0; i < DOG_PAGE_WIDTH; i++ )
dog_page_buffer = 0;
void dog_StartPage(void)
dog_curr_page = 0;
dog_min_y = 0;
dog_ClearPage();
uint8_t dog_NextPage(void)
dog_transfer_page();
dog_ClearPage();
dog_curr_page++;
if ( dog_curr_page >= DOG_PAGE_CNT )
return 0;
dog_min_y = DOG_PAGE_HEIGHT;
dog_min_y *= dog_curr_page;
dog_max_y = dog_min_y;
dog_max_y += DOG_PAGE_HEIGHT-1;
return 1;
/* basic graphic functions */
unsigned char dog_bit_to_mask[8] = { 1, 2, 4, 8, 16, 32, 64, 128 };
void dog_SetPixel(uint8_t x, uint8_t y)
unsigned char tmp;
if ( x < 128 )
if ( y >= dog_min_y && y <=dog_max_y )
tmp = y;
tmp &= (unsigned char)7;
tmp = dog_bit_to_mask[tmp];
dog_page_buffer[x] |= tmp;
void dog_ClrPixel(uint8_t x, uint8_t y)
unsigned char tmp;
if ( x < 128 )
tmp = y;
tmp ^= 0x0ff;
dog_page_buffer[x] &= tmp;
unsigned char dog_mask0[8] = { 0x01, 0x03, 0x07, 0x0f, 0x1f, 0x3f, 0x7f, 0xff };
unsigned char dog_mask7[8] = { 0xff, 0xfe, 0xfc, 0xf8, 0xf0, 0xe0, 0xc0, 0x80 };
static uint8_t dog_get_vline_mask(uint8_t y1, uint8_t y2)
uint8_t tmp;
if ( y1 < dog_min_y )
if ( y2 >= dog_max_y )
/* all bits */
tmp = 0xff;
tmp = y2;
/* bits, starting at bit-position 0 */
tmp = dog_mask0[tmp];
/* bits, ending at bit-position 7 */
tmp = y1;
tmp = dog_mask7[tmp];
/* bits, somewhere in the middle */
uint8_t t2;
tmp = y1;
t2 = y2;
t2 &= (unsigned char)7;
t2= dog_mask0[t2];
tmp &= t2;
return tmp;
/* y1 must be lower or equal to y2 */
void dog_SetVLine(uint8_t x, uint8_t y1, uint8_t y2)
unsigned char *ptr;
if ( x >= 128 )
return;
if ( y2 < dog_min_y )
return;
if ( y1 > dog_max_y )
return;
ptr = dog_page_buffer+x;
*ptr |= dog_get_vline_mask(y1, y2);
void dog_ClrVLine(uint8_t x, uint8_t y1, uint8_t y2)
uint8_t tmp;
unsigned char *ptr;
return;
return;
tmp = dog_get_vline_mask(y1, y2);
tmp ^= 0x0ff;
*ptr &= tmp;
void dog_XorVLine(uint8_t x, uint8_t y1, uint8_t y2)
uint8_t tmp, data;
unsigned char *ptr;
return;
return;
data = *ptr;
data ^= tmp;
*ptr = data;
/* box graphic functions */
void dog_SetBox(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2)
uint8_t x;
for ( x = x1; x <= x2; x++ )
dog_SetVLine(x,y1,y2);
void dog_ClrBox(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2)
uint8_t x;
dog_ClrVLine(x,y1,y2);
void dog_XorBox(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2)
uint8_t x;
dog_XorVLine(x,y1,y2);
/* font functions */
FONT
offsetsize
0wordcapital A index
2wordsmall a index
4bytebbox width
5bytebbox height
6bytebbox descent
7-variable (characters with code 0x20 - 0x7f)
CHARACTER (Format 1)
offsetsize
0bytetotal size of the structure, including this byte
1bits 0..4width
1bits 5..7descent
2byteheight
3-varable (bitmap, topmost line first)
||upper space (ascent area)
|| bboxheight
|| height
|=====|============baseline===
||bbox ddescent
||lower space (descent area)
upper space + lower space = bbox height - height
lower space = bbox descent - descent
upper space = bbox height + descent - height - bbox descent
#define fnt_get_bbox_capital_a(buf) (dog_pgm_read_w((buf)+0))
#define fnt_get_bbox_small_a(buf) (dog_pgm_read_w((buf)+2))
#define fnt_get_bbox_width(buf) (dog_pgm_read((buf)+4))
#define fnt_get_bbox_height(buf) (dog_pgm_read((buf)+5))
#define fnt_get_bbox_descent(buf) (dog_pgm_read((buf)+6))
#define FNT_DATA 7
#define chr_get_len_P(buf) ((unsigned char)(dog_pgm_read((buf)+0)))
#define chr_get_descent_P(buf) (((unsigned char)(dog_pgm_read((buf)+1))) >>5)
#define chr_get_width_P(buf) ((unsigned char)(dog_pgm_read((buf)+1) & (unsigned char)0x1f))
#define chr_get_height_P(buf) ((unsigned char)(dog_pgm_read((buf)+2)))
#define CHR_DATA 3
uint8_t dog_GetFontBBXHeight(PGM_P buf)
return fnt_get_bbox_height(buf);
uint8_t dog_GetFontBBXWidth(PGM_P buf)
return fnt_get_bbox_width(buf);
uint8_t dog_GetFontBBXDescent(PGM_P buf)
return fnt_get_bbox_descent(buf);
static unsigned char chr_get_pixel(PGM_P buf, unsigned char x, unsigned char y )
unsigned char bytes_per_line, index;
/* bytes_per_line = ((unsigned char)chr_get_width(buf)+(unsigned char)7) >> 3; */
bytes_per_line = chr_get_width_P(buf);
bytes_per_line += (unsigned char)7;
bytes_per_line >>= (unsigned char)3;
index = y;
index *= bytes_per_line;
index += (unsigned char)(x>>3);
index += CHR_DATA;
if ( ((unsigned char)dog_pgm_read(buf+index)) & ( (unsigned char)1 << (x&(unsigned char)7)) )
return 1;
return 0;
unsigned short chr_get_skip_delta(PGM_P cbuf, unsigned char skip_cnt)
unsigned short pos = 0;
unsigned char len;
while( skip_cnt > 0 )
len = chr_get_len_P(cbuf + pos);
if ( len == 0 )
return pos;/* should never happen */
pos += (short)len;
skip_cnt--;
return pos;
}fprintf(stderr, "%s\n", );
PGM_P fnt_get_chr(PGM_P fbuf, unsigned char code)
PGM_P adr;
if ( code >= 'a' )
adr = fbuf + fnt_get_bbox_small_a(fbuf);
adr = adr + chr_get_skip_delta(adr, code - 'a');
else if ( code >= 'A' )
adr = fbuf + fnt_get_bbox_capital_a(fbuf);
adr = adr + chr_get_skip_delta(adr, code - 'A');
adr = fbuf + FNT_DATA + chr_get_skip_delta(fbuf+FNT_DATA, code - ' ');
return adr;
uint8_t dog_get_char_width(PGM_P font, unsigned char code)
PGM_P adr;
/* adr = font + FNT_DATA + chr_get_skip_delta(font+FNT_DATA, code - ' '); */
adr = fnt_get_chr(font, code);
return chr_get_width_P(adr);
uint8_t dog_char(uint8_t x, uint8_t y, PGM_P font, uint8_t mode, unsigned char code)
PGM_P cbuf = fnt_get_chr(font, code);
unsigned char ascent_area, descent_area;
unsigned char i, j;
uint8_t tmp_x, tmp_y;
uint8_t height,width;
if ( chr_get_len_P(cbuf) == 0 )
return 0;
height = chr_get_height_P(cbuf);
width= chr_get_width_P(cbuf);
descent_area = fnt_get_bbox_descent(font);
descent_area -= chr_get_descent_P(cbuf);
ascent_area = fnt_get_bbox_height(font);
ascent_area -= height;
ascent_area -= descent_area;
printf("code %c, bbox height %d, aa %d, da %d, char descent %d\n", code, fnt_get_bbox_height(font), ascent_area, descent_area, chr_get_descent(cbuf) );
ascent_area starts at y + chr_get_height(cbuf) - chr_get_descent(cbuf) + ascent_area
char code starts aty + chr_get_height(cbuf) - chr_get_descent(cbuf)
descent area starts aty - chr_get_descent(cbuf)
descent area ends aty - chr_get_descent(cbuf) - descent_area + 1
/*tmp_y = y + chr_get_height(cbuf) - chr_get_descent(cbuf) ;*/
tmp_y = y;
tmp_y += height;
tmp_y -= chr_get_descent_P(cbuf);
/* char goes from tmp_y to tmp_y-height-1 and x .. x + width -1*/
/* y test is done in dog_str */
if ( dog_max_y < tmp_y - height + 1 )
return width;
if ( dog_min_y > tmp_y )
return width;
for( i = height; i > 0; i-- )
tmp_x = x;
for( j = 0; j < width; j++ )
if ( chr_get_pixel(cbuf, j, i-1 ) > 0 )
dog_SetPixel(tmp_x, tmp_y);
dog_ClrPixel(tmp_x, tmp_y);
tmp_x++;
tmp_y--;
return width;
uint8_t dog_DrawChar(uint8_t x, uint8_t y, PGM_P font, unsigned char code)
signed char y0, y1;
y0 = y;
y0 -= fnt_get_bbox_descent(font);
y1 = y0;
y1 += fnt_get_bbox_height(font);
if ( (signed char)dog_max_y < y0 )
return dog_get_char_width(font, code);
if ( (signed char)dog_min_y > y1 )
return dog_char(x,y,font,0,code);
uint8_t dog_get_str_width(PGM_P font, const char *s)
uint8_t w = 0;
while( *s != '\0' )
w+= dog_get_char_width(font, (unsigned char)*s);
s++;
return w;
uint8_t dog_str(uint8_t x, uint8_t y, PGM_P font, uint8_t mode, const char *s)
uint8_t d = 0;
signed char y0, y1;
y0 = y;
y1 = y0;
return dog_get_str_width(font, s);
while( *s != '\0' )
d += dog_char(x+d,y,font, mode, (unsigned char)*s);
s++;
return d;
uint8_t dog_DrawStr(uint8_t x, uint8_t y, PGM_P font, const char *s)
return dog_str(x,y,font,0,s);
char dog_itoa_buf[12];
char *dog_itoa(unsigned long v)
volatile unsigned char i = 11;
dog_itoa_buf[11] = '\0';
while( i > 0)
i--;
dog_itoa_buf = (v % 10)+'0';
v /= 10;
if ( v == 0 )
return dog_itoa_buf+i;
发表于 2014-3-18 20:18:13 | 显示全部楼层
请问下这个是什么型号的12864?
 楼主| 发表于 2014-3-18 23:56:30 | 显示全部楼层
恺之 发表于 2014-3-18 20:18
请问下这个是什么型号的12864?
型号我忘记了,ic是nt7532
发表于 2014-3-19 10:56:25 | 显示全部楼层
代码上看目前已经是从0,0开始的了,所以应该和主代码没有太大关联,建议检查下初始化。
dogm128的这个库也许和你的屏幕不完全匹配。
DOGM128
DOGM132
DOGS102
DOGXL160
Adafruit ST7565 Display
dog_delay(10);
dog_delay(10);
dog_delay(10);
dog_cmd_mode();
dog_delay(300);
dog_delay(300);
发表于 2014-3-19 10:57:39 | 显示全部楼层
dogm128  支持的 设备 主要是 ST7565R, UC1610
 楼主| 发表于 2014-3-19 13:25:02 | 显示全部楼层
dogm128的这个库也 ...
谢谢,谢谢只有先排查初始化了 ,有另外一个屏幕是st7565和这个一样,向右移动三行,
 楼主| 发表于 2014-3-19 16:44:55 | 显示全部楼层
解决了,
  dog_cmd_mode();
  dog_spi_out(0x0b0 | dog_curr_page );         /* select current page  */
  dog_spi_out(0x010 );         /* set upper 4 bit of the col adr to 0 */
  dog_spi_out(0x000 );         /* set lower 4 bit of the col adr to 0 */
修改为
  dog_spi_out(0x003 );         /* set lower 4 bit of the col adr to 0 */
向右移动3像素
DOGM128 也兼容NT7532
发表于 2014-3-20 09:27:26 | 显示全部楼层
界面不错……
发表于 2015-4-10 14:20:00 | 显示全部楼层
终于看到一个玩Camera Axe 的,正准备把它的屏改成汉字12864,dogm128 贵死了
GMT+8, 2026-6-17 22:44 , Processed in 0.040129 second(s), 23 queries .
