查看: 14961|回复: 14
求助 mega2560连接后下载不了程序
发表于 2014-3-21 10:54:04 | 显示全部楼层 |阅读模式
下载就出错  求帮助
找到问题了,是刚插上好着,过几秒就没了
设备管理器里的端口就找不到了
Binary sketch size: 4,552 bytes (of a 258,048 byte maximum)
processing.app.SerialNotFoundException: Serial port 'COM14' not found. Did you select the right one from the Tools > Serial Port menu?
        at processing.app.Serial.<init>(Serial.java:191)
        at processing.app.Serial.<init>(Serial.java:92)
        at processing.app.SerialMonitor.openSerialPort(SerialMonitor.java:207)
        at processing.app.Editor.handleSerial(Editor.java:2481)
        at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:353)
        at java.awt.Component.processMouseEvent(Component.java:6260)
        at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
        at java.awt.Component.processEvent(Component.java:6028)
        at java.awt.Container.processEvent(Container.java:2041)
        at java.awt.Component.dispatchEventImpl(Component.java:4630)
        at java.awt.Container.dispatchEventImpl(Container.java:2099)
        at java.awt.Component.dispatchEvent(Component.java:4460)
        at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
        at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4235)
        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
        at java.awt.Container.dispatchEventImpl(Container.java:2085)
        at java.awt.Window.dispatchEventImpl(Window.java:2475)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
 楼主| 发表于 2014-3-21 12:22:10 | 显示全部楼层
求助啊  求大神帮忙
 楼主| 发表于 2014-3-21 13:30:54 | 显示全部楼层
求助啊  求大神帮助
 楼主| 发表于 2014-3-21 14:21:39 | 显示全部楼层
求助啊求大神帮助
发表于 2014-3-21 14:21:57 | 显示全部楼层
提示没找到这个com14端口,叫你重新设置下
发表于 2014-3-21 14:41:28 | 显示全部楼层
你可以重新插拔一下你的USB连接线,再在工具栏里面选择正确的COM端口
 楼主| 发表于 2014-3-21 15:00:00 | 显示全部楼层
求助啊求大神帮助
 楼主| 发表于 2014-3-21 15:02:36 | 显示全部楼层
那个是灰色的点不了
 楼主| 发表于 2014-3-21 15:36:52 | 显示全部楼层
求助啊求大神帮助
 楼主| 发表于 2014-3-21 16:33:46 | 显示全部楼层
求助啊求大神帮助
发表于 2014-3-21 16:37:10 | 显示全部楼层
无法找到com口表示,计算机驱动没装好,到计算机管理中重新更新驱动,直接右键更新即可,更新后,关一下arduino.exe,拔掉USB线,再插上,再打开arduino.exe。
 楼主| 发表于 2014-3-21 17:03:22 | 显示全部楼层
邓维安 发表于 2014-3-21 16:37
无法找到com口表示,计算机驱动没装好,到计算机管理中重新更新驱动,直接右键更新即可,更新后,关一下ard ...
找到问题了,是刚插上好着,过几秒就没了
设备管理器里的端口就找不到了
 楼主| 发表于 2014-3-21 17:03:50 | 显示全部楼层
找到问题了,是刚插上好着,过几秒就没了
设备管理器里的端口就找不到了
 楼主| 发表于 2014-3-21 17:25:34 | 显示全部楼层
找到问题了,是刚插上好着,过几秒就没了
设备管理器里的端口就找不到了
发表于 2014-3-22 10:12:06 | 显示全部楼层
解决了吗?
GMT+8, 2026-7-28 20:41 , Processed in 0.048252 second(s), 22 queries .
