查看: 10025|回复: 1
小白求助enc28J60 问题
发表于 2014-3-27 15:24:59 | 显示全部楼层 |阅读模式
#include <EtherCard.h>
static byte mymac[] = {0xDD,0xDD,0xDD,0x00,0x00,0x01};
char website[] PROGMEM = "www.lucadentella.it";
byte Ethernet::buffer[700];
static uint32_t timer;
static void response_callback (byte status, word off, word len) {
  Serial.print((const char*) Ethernet::buffer + off + 207);
void setup () {
  Serial.begin(57600);
  Serial.println("Client Demo");
  Serial.println();
  if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
    Serial.println( "Failed to access Ethernet controller");
   Serial.println("Ethernet controller initialized");
Serial.println();
  if (!ether.dhcpSetup())
    Serial.println("Failed to get configuration from DHCP");
    Serial.println("DHCP configuration done");
  ether.printIp("IP Address:\t", ether.myip);
  ether.printIp("Netmask:\t", ether.mymask);
  ether.printIp("Gateway:\t", ether.gwip);
  Serial.println();
  if (!ether.dnsLookup(website))
    Serial.println("DNS failed");
    Serial.println("DNS resolution done");
  ether.printIp("SRV IP:\t", ether.hisip);
  Serial.println();
  ether.packetLoop(ether.packetReceive());
  if (millis() > timer) {
    timer = millis() + 5000;
    ether.browseUrl(PSTR("/demo/"), "aphorisms.php", website, response_callback);
下面是报错的信息:
_3_Client.ino: In function 'void setup()':
_3_Client:32: error: 'class EtherCard' has no member named 'mymask'
这是哪里出问题了, 求指教
发表于 2014-3-28 16:52:56 | 显示全部楼层
这个例子有问题,应该是netmask, 我遇到过同样的问题
GMT+8, 2026-7-28 17:58 , Processed in 0.067083 second(s), 18 queries .
