查看: 6033|回复: 4
Arduino接RN-42後連接mindwave測量attention值
发表于 2014-3-27 17:52:16 | 显示全部楼层 |阅读模式
我的poorquality=0時LED燈會亮
但為何我的Attention值一直都是0
程式碼如下
// Arduino Bluetooth Interface with Mindwave
// This is example code provided by NeuroSky, Inc. and is provided
// license free.
#define LED 13
#define BAUDRATE 57600
#define DEBUGOUTPUT 0
#define GREENLED1  3
#define GREENLED2  4
#define GREENLED3  5
#define YELLOWLED1 6
#define YELLOWLED2 7
#define YELLOWLED3 8
#define YELLOWLED4 9
#define REDLED1    10
#define REDLED2    11
#define REDLED3    12
#define powercontrol 10
// checksum variables
byte generatedChecksum = 0;
byte checksum = 0;
int payloadLength = 0;
byte payloadData[64] = {
  0};
byte poorQuality = 0;
byte attention = 0;
byte meditation = 0;
// system variables
long lastReceivedPacket = 0;
boolean bigPacket = false;
// Microprocessor Setup //
  pinMode(GREENLED1, OUTPUT);
  pinMode(GREENLED2, OUTPUT);
  pinMode(GREENLED3, OUTPUT);
  pinMode(YELLOWLED1, OUTPUT);
  pinMode(YELLOWLED2, OUTPUT);
  pinMode(YELLOWLED3, OUTPUT);
  pinMode(YELLOWLED4, OUTPUT);
  pinMode(REDLED1, OUTPUT);
  pinMode(REDLED2, OUTPUT);
  pinMode(REDLED3, OUTPUT);
  pinMode(LED, OUTPUT);
  Serial.begin(BAUDRATE);           // USB
// Read data from Serial UART //
byte ReadOneByte() {
  int ByteRead;
  while(!Serial.available());
  ByteRead = Serial.read();
#if DEBUGOUTPUT
  Serial.print((char)ByteRead);   // echo the same byte out the USB serial (for debug purposes)
#endif
  return ByteRead;
//MAIN LOOP//
  // Look for sync bytes
  if(ReadOneByte() == 170) {
      payloadLength = ReadOneByte();
      if(payloadLength > 169)                      //Payload length can not be greater than 169
          return;
      for(int i = 0; i < payloadLength; i++) {
        payloadData[i] = ReadOneByte();            //Read payload into memory
        generatedChecksum += payloadData[i];
      checksum = ReadOneByte();                      //Read checksum byte from stream
      generatedChecksum = 255 - generatedChecksum;   //Take one's compliment of generated checksum
        if(checksum == generatedChecksum) {
        poorQuality = 200;
        attention = 0;
        meditation = 0;
        for(int i = 0; i < payloadLength; i++) {    // Parse the payload
          switch (payloadData[i]) {
          case 2:
            i++;
            poorQuality = payloadData[i];
            bigPacket = true;
          case 4:
            i++;
            attention = payloadData[i];
          case 5:
            i++;
            meditation = payloadData[i];
          case 0x80:
            i = i + 3;
          case 0x83:
            i = i + 25;
          default:
          } // switch
        } // for loop
#if !DEBUGOUTPUT
        // *** Add your code here ***
        if(bigPacket) {
          if(poorQuality == 0)
            digitalWrite(LED, HIGH);
            digitalWrite(LED, LOW);
          Serial.print("PoorQuality: ");
          Serial.print(poorQuality, DEC);
          Serial.print(" Attention: ");
          Serial.print(attention, DEC);
          Serial.print(" Time since last packet: ");
          Serial.print(millis() - lastReceivedPacket, DEC);
          lastReceivedPacket = millis();
          Serial.print("\n");
          switch(attention / 10) {
          case 0:
            digitalWrite(GREENLED1, HIGH);
            digitalWrite(GREENLED2, LOW);
            digitalWrite(GREENLED3, LOW);
            digitalWrite(YELLOWLED1, LOW);
            digitalWrite(YELLOWLED2, LOW);
            digitalWrite(YELLOWLED3, LOW);
            digitalWrite(YELLOWLED4, LOW);
            digitalWrite(REDLED1, LOW);
            digitalWrite(REDLED2, LOW);
            digitalWrite(REDLED3, LOW);
          case 1:
            digitalWrite(GREENLED2, HIGH);
          case 2:
            digitalWrite(GREENLED3, HIGH);
          case 3:
            digitalWrite(YELLOWLED1, HIGH);
          case 4:
            digitalWrite(YELLOWLED2, HIGH);
          case 5:
            digitalWrite(YELLOWLED3, HIGH);
          case 6:
            digitalWrite(YELLOWLED4, HIGH);
          case 7:
            digitalWrite(REDLED1, HIGH);
          case 8:
            digitalWrite(REDLED2, HIGH);
          case 9:
            digitalWrite(REDLED3, HIGH);
          case 10:
#endif
        bigPacket = false;
      else {
        // Checksum Error
      }  // end if else for checksum
    } // end if read 0xAA byte
发表于 2014-3-28 09:18:26 | 显示全部楼层
//Mindset setup
  pinMode(BLUESMIRFON, OUTPUT);
  digitalWrite(BLUESMIRFON, HIGH);
  Serial.flush();
 楼主| 发表于 2014-3-30 21:05:59 | 显示全部楼层
邓维安 发表于 2014-3-28 09:18
//Mindset setup
試了
poorquality可以出來
但是我的attention值還是有問題
是因為我是用arduino uno 的關係嗎
 楼主| 发表于 2014-3-30 21:54:29 | 显示全部楼层
x824172002 发表于 2014-3-30 21:05
試了
poorquality可以出來
但是我的attention值還是有問題
以解決~~~謝謝喔~~~~~~~~~~~
发表于 2014-9-24 01:04:47 | 显示全部楼层
你好,neurosky sample code 我遇到的情況跟你一樣,看到樓上大大的解決方法,LED卻還是一直只執行到 case 0,請問大大如何解答??
萬萬感謝
GMT+8, 2026-6-15 18:20 , Processed in 0.037349 second(s), 20 queries .
