查看: 21041|回复: 20
Ardunio的内存到底是怎么控制的?
发表于 2014-4-3 17:06:48 | 显示全部楼层 |阅读模式
  1. static const byte  image[] = {
  2. 0,255,128,0,0,0,0,1,0,2,0,3,0,4,0,5,0,6,0,7,0,8,0,9,0,10,0,11,0,12,0,13,0,14,0,15,0,16,0,17,
  3. 0,18,0,19,0,20,0,21,0,22,0,23,0,24,0,25,0,26,0,27,0,28,0,29,0,30,0,31,
  4. 1,0,1,1,1,2,1,3,1,4,1,5,1,6,1,7,1,8,1,9,1,10,1,11,1,12,1,13,1,14,1,15,1,16,1,17,
  5. 1,18,1,19,1,20,1,21,1,22,1,23,1,24,1,25,1,26,1,27,1,28,1,29,1,30,1,31,
  6. 2,0,2,1,2,2,2,3,2,4,2,5,2,6,2,7,2,8,2,9,2,10,2,11,2,12,2,13,2,14,2,15,2,16,2,17,
  7. 2,18,2,19,2,20,2,21,2,22,2,23,2,24,2,25,2,26,2,27,2,28,2,29,2,30,2,31,
  8. 3,0,3,1,3,2,3,3,3,4,3,5,3,6,3,7,3,8,3,9,3,10,3,11,3,12,3,13,3,14,3,15,3,16,3,17,
  9. 3,18,3,19,3,20,3,21,3,22,3,23,3,24,3,25,3,26,3,27,3,28,3,29,3,30,3,31,
  10. 4,0,4,1,4,2,4,3,4,4,4,5,4,6,4,7,4,8,4,9,4,10,4,11,4,12,4,13,4,14,4,15,4,16,4,17,
  11. 4,18,4,19,4,20,4,21,4,22,4,23,4,24,4,25,4,26,4,27,4,28,4,29,4,30,4,31,
  12. 5,0,5,1,5,2,5,3,5,4,5,5,5,6,5,7,5,8,5,9,5,10,5,11,5,12,5,13,5,14,5,15,5,16,5,17,
  13. 5,18,5,19,5,20,5,21,5,22,5,23,5,24,5,25,5,26,5,27,5,28,5,29,5,30,5,31,
  14. 6,0,6,1,6,2,6,3,6,4,6,5,6,6,6,7,6,8,6,9,6,10,6,11,6,12,6,13,6,14,6,15,6,16,6,17,
  15. 6,18,6,19,6,20,6,21,6,22,6,23,6,24,6,25,6,26,6,27,6,28,6,29,6,30,6,31,
  16. 7,0,7,1,7,2,7,3,7,4,7,5,7,6,7,7,7,8,7,9,7,10,7,11,7,12,7,13,7,14,7,15,7,16,7,17,
  17. 7,18,7,19,7,20,7,21,7,22,7,23,7,24,7,25,7,26,7,27,7,28,7,29,7,30,7,31,
  18. 8,0,8,1,8,2,8,3,8,4,8,5,8,6,8,7,8,8,8,9,8,10,8,11,8,12,8,13,8,14,8,15,8,16,8,17,
  19. 8,18,8,19,8,20,8,21,8,22,8,23,8,24,8,25,8,26,8,27,8,28,8,29,8,30,8,31,
  20. 9,0,9,1,9,2,9,3,9,4,9,5,9,6,9,7,9,8,9,9,9,10,9,11,9,12,9,13,9,14,9,15,9,16,9,17,
  21. 9,18,9,19,9,20,9,21,9,22,9,23,9,24,9,25,9,26,9,27,9,28,9,29,9,30,9,31,
  22. 10,0,10,1,10,2,10,3,10,4,10,5,10,6,10,7,10,8,10,9,10,10,10,11,10,12,10,13,10,14,
  23. 10,15,10,16,10,17,10,18,10,19,10,20,10,21,10,22,10,23,10,24,10,25,10,26,10,27,10
  24. ,28,10,29,10,30,10,31,
  25. 11,0,11,1,11,2,11,3,11,4,11,5,11,6,11,7,11,8,11,9,11,10,11,11,11,12,11,13,11,14,
  26. 11,15,11,16,11,17,11,18,11,19,11,20,11,21,11,22,11,23,11,24,11,25,11,26,11,27,11
  27. ,28,11,29,11,30,11,31,
  28. 12,0,12,1,12,2,12,3,12,4,12,5,12,6,12,7,12,8,12,9,12,10,12,11,12,12,12,13,12,14,
  29. 12,15,12,16,12,17,12,18,12,19,12,20,12,21,12,22,12,23,12,24,12,25,12,26,12,27,12
  30. ,28,12,29,12,30,12,31,
  31. 13,0,13,1,13,2,13,3,13,4,13,5,13,6,13,7,13,8,13,9,13,10,13,11,13,12,13,13,13,14,
  32. 13,15,13,16,13,17,13,18,13,19,13,20,13,21,13,22,13,23,13,24,13,25,13,26,13,27,13
  33. ,28,13,29,13,30,13,31,
  34. 14,0,14,1,14,2,14,3,14,4,14,5,14,6,14,7,14,8,14,9,14,10,14,11,14,12,14,13,14,14,
  35. 14,15,14,16,14,17,14,18,14,19,14,20,14,21,14,22,14,23,14,24,14,25,14,26,14,27,14
  36. ,28,14,29,14,30,14,31,
  37. 15,0,15,1,15,2,15,3,15,4,15,5,15,6,15,7,15,8,15,9,15,10,15,11,15,12,15,13,15,14,
  38. 15,15,15,16,15,17,15,18,15,19,15,20,15,21,15,22,15,23,15,24,15,25,15,26,15,27,15
  39. ,28,15,29,15,30,15,31
  40. };
  41. void setup() {
  42.   // put your setup code here, to run once:
  43. Serial.begin(9600);
  44. for(int i=0;i<sizeof(image);i++)
  45. Serial.println(image[i]);
  46. }
  47. void loop() {
  48.   // put your main code here, to run repeatedly:
  49. }
打印的结果不可控制,,,求解。。。
发表于 2014-4-3 17:17:19 | 显示全部楼层
是否超出了 SRAM 的上限?
 楼主| 发表于 2014-4-3 17:18:36 | 显示全部楼层
Super169 发表于 2014-4-3 17:17
是否超出了 SRAM 的上限?
SRAM 这是Ardunio的存储器?
发表于 2014-4-3 17:18:37 | 显示全部楼层
如果是 static const 的話, 用 PROGMEM 會更好, 節省寶貴的 SRAM.
 楼主| 发表于 2014-4-3 17:20:05 | 显示全部楼层
但是输出的结果不是原来数组的。。。。
发表于 2014-4-3 17:21:46 | 显示全部楼层
PROGMEM定义的数据保存在flash中需要用专用函数读出来
发表于 2014-4-3 17:24:11 | 显示全部楼层
suyulingxm 发表于 2014-4-3 17:18
SRAM 这是Ardunio的存储器?
Yes, 是用來儲存可以在程式執行時改變數值的資料.
如果是 const, 放到 PROGMEM (flash) 中也可以了.
 楼主| 发表于 2014-4-3 17:24:42 | 显示全部楼层
那这个专用的函数名字是?
 楼主| 发表于 2014-4-3 17:26:24 | 显示全部楼层
我这么大的数据量,,,其打印的数据都是乱的
发表于 2014-4-3 17:28:38 | 显示全部楼层
suyulingxm 发表于 2014-4-3 17:20
但是输出的结果不是原来数组的。。。。
我用 Nano 328 測試過沒問題, 所以才懷疑你用的是只有 1K SRAM 的 Arduino.
如果記憶體足夠, 會不會是你的 Baudrate 不配合?
你看到的結果是怎樣的?
发表于 2014-4-3 17:31:44 | 显示全部楼层
只是改一句 code, 值得的.
最近在研究 顯示的問題, 一頁的 display buffer 就用了 1KB, 我還在研究是否要把最後的 1KB 內置 EEPROM 也用上.
 楼主| 发表于 2014-4-3 17:34:55 | 显示全部楼层
0
0
184
0
0
0
1
0
0
184
184
184
184
184
184
184
0
0
135
0
0
184
0
0
1
3
0
184
18
0
0
0
0
0
0
0
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
1
4
239
0
0
184
0
184
0
248
254
255
0
0
184
184
2
184
6
184
207
0
0
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
184
我的是UNO。。。难道买上山寨货了?
发表于 2014-4-3 17:39:26 | 显示全部楼层
suyulingxm 发表于 2014-4-3 17:34
0
0
184
我在 nano 上試過, 完全沒有問題.  出來的數字跟程式中的一樣.
你可以試試用 PROGMEM, 在這裡有詳細說明: http://arduino.cc/en/Reference/PROGMEMhttp://arduino.cc/en/Reference/PROGMEM
基本上加一個 PROGMEM 的字, 讀取時改成 pgm_read_byte 或 pgm_read_word 的語法就可以了.
发表于 2014-4-3 17:44:44 | 显示全部楼层
0
0
184
难道买上山寨货了?
arduino 可是 hardware opensource 的, 難道你用的是原廠來路正品??
我用的可是貨真價實的 國產山寨貨.
发表于 2014-4-3 17:49:53 | 显示全部楼层
試試這樣修改, 看看用 PROGMEM 是否可以:
  1. PROGMEM byte  image[] = {
  2. };
  3. void setup() {
  4.   // put your setup code here, to run once:
  5. Serial.begin(9600);
  6. for(int i=0;i<sizeof(image);i++)
  7. Serial.println(pgm_read_byte(&(image[i])));
  8. }
  9. void loop() {
  10.   // put your main code here, to run repeatedly:
  11. }
GMT+8, 2026-7-28 23:07 , Processed in 0.035050 second(s), 19 queries .
