查看: 12462|回复: 9
关于DS1302
发表于 2014-4-10 15:46:25 | 显示全部楼层 |阅读模式
我用mega2560,5,6,7分别接DS1302的SCLK,IO,CE,但是时间显示
我是根据  Arduino学习笔记A8 - Arduino 连接 DS1302时钟模块  中提供的1.0可用库文件及自带例子弄的。
设定37秒,确实过了23S 分的那个数据会变,但是数字显示完全不对。
是不是需要上拉电阻?能不能内部上拉(似乎有说只有input才能内部上拉)?
Example sketch for interfacing with the DS1302 timekeeping chip.
Copyright (c) 2009, Matt Sparks
All rights reserved.
http://quadpoint.org/projects/arduino-ds1302
#include <stdio.h>
#include <string.h>
#include <DS1302.h>
/* Set the appropriate digital I/O pin connections */
uint8_t CE_PIN   = 5;
uint8_t IO_PIN   = 6;
uint8_t SCLK_PIN = 7;
/* Create buffers */
char buf[50];
char day[10];
/* Create a DS1302 object */
DS1302 rtc(CE_PIN, IO_PIN, SCLK_PIN);
void print_time()
  /* Get the current time and date from the chip */
  Time t = rtc.time();
  /* Name the day of the week */
  memset(day, 0, sizeof(day));  /* clear day buffer */
  switch (t.day) {
    case 1:
      strcpy(day, "Sunday");
    case 2:
      strcpy(day, "Monday");
    case 3:
      strcpy(day, "Tuesday");
    case 4:
      strcpy(day, "Wednesday");
    case 5:
      strcpy(day, "Thursday");
    case 6:
      strcpy(day, "Friday");
    case 7:
      strcpy(day, "Saturday");
  /* Format the time and date and insert into the temporary buffer */
  snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",
           day,
           t.yr, t.mon, t.date,
           t.hr, t.min, t.sec);
  /* Print the formatted string to serial so we can see the time */
  Serial.println(buf);
  /* Initialize a new chip by turning off write protection and clearing the
     clock halt flag. These methods needn't always be called. See the DS1302
     datasheet for details. */
  rtc.write_protect(false);
  rtc.halt(false);
  /* Make a new time object to set the date and time */
  /*   Tuesday, May 19, 2009 at 21:16:37.            */
  Time t(2009, 5, 19, 21, 16, 37, 3);
  /* Set the time and date on the chip */
  rtc.time(t);
/* Loop and print the time every second */
  print_time();
  delay(1000);
发表于 2014-4-10 16:40:44 | 显示全部楼层
线太长了,或者是杜邦线,面包线接触不好。
 楼主| 发表于 2014-4-10 16:45:04 | 显示全部楼层
20CM的公母头,貌似没有更短的了诶....那上拉能不能解决?
发表于 2014-4-10 18:10:10 | 显示全部楼层
算法错了吧。
发表于 2014-4-10 21:49:03 | 显示全部楼层
程序没看明白,好似就是在setup里设置了一下时间,然后loop里循环显示时间。 为什么会变呢?不明白
 楼主| 发表于 2014-4-11 00:27:22 | 显示全部楼层
时间变化是DS1302模块..arduino只是读取和设置而已。1302的库也应该是没问题的。
发表于 2014-4-11 00:35:12 | 显示全部楼层
我是指时间从 1:42:49 一下变成 1:23:00 。 每秒变的那是正常的
 楼主| 发表于 2014-4-11 11:06:52 | 显示全部楼层
哦.查来查去要么就是模块问题,要么就是干扰,实在不行换个3231试试- -
发表于 2014-4-11 15:25:53 | 显示全部楼层
1307我有一个,很不准,半个月快了2个小时,  3231刚买的试了试 10天慢了2秒,应该还算不错的成绩。价格都差不多
发表于 2014-4-15 10:36:33 | 显示全部楼层
我也遇到过这个问题,碰一下显示就不正常。不信你用线焊上去试试,显示就正常了。
GMT+8, 2026-7-28 18:52 , Processed in 0.039606 second(s), 21 queries .
