查看: 11881|回复: 2
NRF2401延遲問題~請教各位版主跟各位大神
发表于 2014-4-10 17:46:04 | 显示全部楼层 |阅读模式
看各位大神玩NRF2401挺好玩的,所以就敗了一組回來玩玩看,我用RF24的範例做兩個NRF2401的傳輸,但是有發現一個問題,在正常傳輸下,按下主機的RESET後,從機可以很快的連上,但是按下從機的RESET後,卻要花上7~9秒才會處理主機發來的信號,我有嘗試過將IRQ的引腳拉低,也做過延遲時間,狠了狠心也試過兩個對調,但是好像沒什麼作用,請教各位大神有辦法讓這個情況改善嗎?我該從哪個地方去著手,也看過有人說要將FIFO清空,也順便請教各問論壇的大神們,怎麼做最基本的清空動作?
特別貼上影片,我的板子~~
也試過這個外國人的作法,也如法炮製的修修改改....結果~~跟沒改過的狀況一樣
http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
ORZ 在Arduino前一個禮拜的新手......
使用器材
arduino UNR R3*2
NRF2401 *2
使用庫
RF24
RF24Network
因為改完後跟原版一樣...所以貼上原稿
(自己修修改改的程式碼,改得比阿拉伯文還要看不懂.....索性貼上原稿 )
//////////////////////////////////////主機-發送信號/////////////////////////////////////
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
// nRF24L01(+) radio attached using Getting Started board
RF24 radio(9,10);
// Network uses that radio
RF24Network network(radio);
// Address of our node
const uint16_t this_node = 1;
// Address of the other node
const uint16_t other_node = 0;
// How often to send 'hello world to the other unit
const unsigned long interval = 150; //ms
// When did we last send?
unsigned long last_sent;
// How many have we sent already
//unsigned long packets_sent;
// Structure of our payload
struct payload_t
  uint32_t ms;
  uint32_t sensorDataA;
  uint32_t sensorDataB;
boolean power_SW;
int led_VOL;
void setup(void)
  Serial.begin(115200);
  Serial.println("RF24Network/examples/helloworld_tx/");
  SPI.begin();
  radio.begin();
  radio.setDataRate( RF24_250KBPS ) ;
  network.begin(/*channel*/ 50, /*node address*/ this_node);
  randomSeed(analogRead(0));
  pinMode(7,INPUT_PULLUP);
void loop(void)
  power_SW=!digitalRead(7);
  led_VOL=analogRead(A0)/4;
  // Pump the network regularly
  network.update();
  // If it's time to send a message, send it!
  unsigned long now = millis();
  if ( now - last_sent >= interval  )
    last_sent = now;
    Serial.print("power_SW:");
    Serial.println(power_SW);
    Serial.print("led_VOL:");
    Serial.println(led_VOL);
    Serial.print("Sending...");
    payload_t payload = {
      millis(),power_SW,led_VOL    };
    RF24NetworkHeader header(/*to node*/ other_node);
    bool ok = network.write(header,&payload,sizeof(payload));
    if (ok)
      Serial.println("ok.");
      Serial.println("failed.");
//////////////////////////////////////從機-接收信號/////////////////////////////////////
#include <RF24.h>
#include <SPI.h>
RF24 radio(9,10);
const uint16_t this_node = 0;
const uint16_t other_node = 1;
struct payload_t
  uint32_t ms;
#define power_PIN 5
#define led_PIN 6
boolean power_SW;
int led_VOL;
void setup(void)
  SPI.begin();
  radio.begin();
  pinMode(power_PIN,OUTPUT);
  pinMode(led_PIN,OUTPUT);
void loop(void)
  network.update();
  // Is there anything ready for us?
  while ( network.available() )
    // If so, grab it and print it out
    RF24NetworkHeader header;
    payload_t payload;
    network.read(header,&payload,sizeof(payload));
    power_SW=payload.sensorDataA;
    led_VOL=payload.sensorDataB;
  digitalWrite(power_PIN,power_SW);
  analogWrite(led_PIN,led_VOL);
发表于 2014-4-28 03:18:39 | 显示全部楼层
你有試過傳送字串會有延遲情形嗎?
 楼主| 发表于 2014-5-8 18:48:24 | 显示全部楼层
字串也是有延遲的現象...
GMT+8, 2026-7-29 02:58 , Processed in 0.061093 second(s), 19 queries .
