查看: 10205|回复: 0
Socket方式数据上传声音传感器至machtalk.net物联网平台案例
发表于 2014-4-14 16:13:46 | 显示全部楼层 |阅读模式
www.machtalk.net
1、硬件准备
与例二相同。machtalk.net 声音传感器数据采集案例
http://www.geek-workshop.com/thread-9326-1-1.html
2、硬件连接
与例二相同。
3、烧写代码
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(192,168,0,12);
EthernetClient client;
IPAddress server(60,211,253,162);
//char server[] = "api.machtalk.net";
unsigned long lastConnectionTime = 0;
boolean lastConnected = false;
const unsigned long postingInterval = 10*1000;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Ethernet.begin(mac, ip);
  // read the analog sensor:
  int sensorReading = analogRead(A0);
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected() && lastConnected) {
    Serial.println();
    client.stop();
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    sendData(sensorReading);
  lastConnected = client.connected();
void sendData(int thisData) {
  // if there's a successful connection:
  if (client.connect(server, 7777)) {
    // socket:
    client.println("{\"cmd\":\"create\",\"data\": {\"APIKey\":\"7a19bd7874a541a6b4c50a831ea0b3b2\",\"device_id\":\"7bc8abb1b3cb434499e66ba39c206aba\",\"device_value_id\":\"1\",\"device_type_id\":\"1\"}}");
    client.print("{\"cmd\":\"post\",\"data\":{\"value\":");
    client.print(thisData);
    client.println("}}");
    client.println("{\"cmd\":\"close\"}");
  else {
    // if you couldn't make a connection:
    Serial.println();
    client.stop();
   // note the time that the connection was made or attempted:
平台配置
平台配置如案例二类似。
machtalk.net物联网平台技术交流群:300250166
GMT+8, 2026-7-28 23:02 , Processed in 0.033518 second(s), 17 queries .
