查看: 11497|回复: 7
传感器和gps实现电脑串口显示通讯。现在的问题是程序执行一段时间就会停止。求帮助
发表于 2014-4-15 16:27:07 | 显示全部楼层 |阅读模式
#include <Wire.h>
#include <SoftwareSerial.h>
#include <string.h>
#include <TinyGPS.h>
#define u16 unsigned int
#define u8  unsigned char
#define u32 unsigned long
#define u64 unsigned long long
#define MS5611 0x77
#define Reset  0x1e
#define Temperature 0x50
#define Pressure          0x40
#define        CONV   0x40
#define READ   0x00
#define OSR           0x08
#define D1           0x00
#define        D2           0x10
#define        PROM_RD        0xa0
u8 i;
uint32_t  d1;
uint32_t  d2;
int32_t TEMP = 0;
u16 Prom[8];
float P,T,dT,OFF,SENS;
float Tem;
float Pre;
const float sea_press = 1013.25;
SoftwareSerial GPS(8, 9); //4RX,5TX
TinyGPS gps;
unsigned long fix_age;
long lat, lon;
float LAT, LON;
void gpsdump(TinyGPS &gps);
//bool feedgps();
//void getGPS();  // gps初始化结束
void initial(u8 address)
// Serial.println();
// Serial.println("PROM COEFFICIENTS ivan");
  Wire.beginTransmission(address);
  Wire.write(0x1E); // reset
  Wire.endTransmission();
  delay(10);
  for (int i=0; i<6  ; i++)
    Wire.write(0xA2 + (i * 2));
    Wire.requestFrom(address, (u8) 6);
    delay(1);
    if(Wire.available())
    Prom[i+1] = Wire.read() << 8 | Wire.read();    }
      Serial.println("Error reading PROM 1");  }
      Serial.println(Prom[i+1]);
    Serial.println();
    // GPS.begin(9600);                   // GPS module baud rate
    // Serial.begin(9600);                  // the Serial port of Arduino baud rate.
     //delay(500);
long getVal(int address, byte code)
unsigned long ret = 0;
Wire.write(code);
delay(10);  // start read sequence
Wire.write((byte) 0x00);
Wire.requestFrom(address, (int)3);
if (Wire.available() >= 3)
{    ret = Wire.read() * (unsigned long)65536 + Wire.read() * (unsigned long)256 + Wire.read();  }
else {    ret = -1;  }
return ret;
int lightsensorvolue;
byte dht_dpin=7;
byte dht_dat[5];
void setup(){{
   Serial.begin(9600);//通信
   delay(300);
   GPS.begin(9600);
    delay(500);
Wire.begin();
  initial(MS5611);
  delay(5);
InitDHT();//温度定义开始
//Serial.println("HELLO READY GO\n\n");
delay(1000);//温度定义结束
    int32_t T1    = 0;
    int64_t OFF1  = 0;
    int64_t SENS1 = 0;
    d1 = getVal(MS5611,0x48);//temp
    d2 = getVal(MS5611,0x58);//pressure
    dT   = d2 - ((int32_t)Prom[5] << 8);
    OFF = ((int64_t)Prom[2]*pow(2,17) + dT*Prom[4]/pow(2,6));
    SENS = ((int64_t)Prom[1]*pow(2,16) + dT*Prom[3]/pow(2,7));
    T = 2000+((float)(dT*Prom[6]))/pow(2,23);
    if(T< 2000) // if temperature lower than 20 Celsius
    T1    = pow(dT, 2) / 2147483648;
    OFF1  = 5 * pow((T - 2000), 2) / 2;
    SENS1 = 5 * pow((T - 2000), 2) / 4;
    if(TEMP < -1500) // if temperature lower than -15 Celsius
        OFF1  = OFF1 + 7 * pow((T + 1500), 2);
        SENS1 = SENS1 + 11 * pow((T + 1500), 2) / 2;
    T -= T1;
    OFF -= OFF1;
   SENS -= SENS1;
    Tem = (float)T/ 100;
    Pre =((((float)(d1*SENS))/pow(2,21) - OFF)/pow(2,15))/100;
    Serial.print("1.Actual TEMP= ");
    Serial.print(Tem);
    Serial.print("   Actual PRESSURE= ");
    Serial.println(Pre);
    delay(1000);//大气压结束
  StartDHT22();//温湿开始
  for (byte i=0;i<5;i++)
  dht_dat[i] = readByte();
  byte checksum=dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];
  if(dht_dat[4] == checksum){
    int HighByte = dht_dat[0];
    int LowByte = dht_dat[1];
    int TReading = (HighByte << 8) + LowByte;
    int Whole = TReading / 10;
    int Fract = TReading % 10;
    Serial.print("3.humidity=");
    Serial.print(Whole);
    Serial.print(".");
    Serial.print(Fract);
    Serial.print("%");
    HighByte = dht_dat[2];
    LowByte = dht_dat[3];
    TReading = (HighByte<<8)+LowByte;
    Whole=TReading/10;
    Fract=TReading%10;
    Serial.print("   temperature =");
    int SignBit = TReading & 0x8000;
    if(SignBit)
      Serial.print("-");
      Serial.print(".");
      Serial.println("C");
delay(1000);
        myGPS();
        delay(2000);
lightsensorvolue=analogRead(A3);
  if (analogRead(A3)>400){
  Serial.print("2.OPEN:");
  Serial.println( analogRead(A3));
  if(analogRead(A3)<400){
Serial.print( "2.CLOSE:");
Serial.println(analogRead(A3));
  delay(2000);//延时2S,
void InitDHT()
pinMode(dht_dpin,OUTPUT);
digitalWrite(dht_dpin,HIGH);
void StartDHT22(){
digitalWrite(dht_dpin,LOW);
delay(1);
delayMicroseconds(40);
pinMode(dht_dpin,INPUT);
while(digitalRead(dht_dpin)==LOW);
while(digitalRead(dht_dpin)==HIGH);
byte readByte(){
byte result=0;
for(byte i=0;i<8;i++){
delayMicroseconds(45);
if(digitalRead(dht_dpin)==HIGH)
  result  |= ( 1 <<(7-i));
  while (digitalRead(dht_dpin)==HIGH);
return result;//温湿度结束
delay(2000);
void myGPS()
  // GPS.begin(9600);
  //delay(30);
int counter=0;
//GPS.listen();
//for (;;)
   long lat, lon;
   //unsigned long fix_age, time, date, speed, course;
   //unsigned long chars;
  // unsigned short sentences, failed_checksum;
   long Latitude, Longitude;
   gps.get_position(&lat, &lon,&fix_age);
   getGPS();
   Serial.print("4.Latitude : ");
   Serial.print(LAT/1000000,7);
   Serial.print(" :: Longitude : ");
   Serial.println(LON/1000000,7);
/*  if (LAT == 0 && LON == 0)
    continue;
  counter ;
  if (counter<30)
    continue;
void getGPS()
   bool newdata = false;
   unsigned long start = millis();
   while (millis() - start < 2000)
      if (feedgps ())
         newdata = true;
     if (newdata)
      gpsdump(gps);
bool feedgps()
   while (GPS.available())
      if (gps.encode(GPS.read()))
        return true;
      }return 0;
   gps.get_position(&lat, &lon);
   LAT = lat;
   LON = lon;
      feedgps();
     delay(3000);
发表于 2014-4-15 18:23:07 | 显示全部楼层
請問執行多久才會停止, 如果時間不太長的話, 多加一些 debug 用的 Serial.print, 先簡單看看在那裡停了吧.
 楼主| 发表于 2014-4-15 20:01:32 | 显示全部楼层
停止的时间不一定,都是在执行完光感传感器之后就会停止。我怀疑是gps的串口通讯和其他三个传感器互相之间干扰。
发表于 2014-4-15 20:40:10 | 显示全部楼层
理論上干擾只會影響得到的數值, 應該不會導致程式停止.
由於看不到庫的內容, 假設不會有問題.
而在你的程式中, 比較有可能出現停止的可能是  while (GPS.available()); 如果 GPS 有問題, 可能會一直在等 (只是猜測, 不能確定).
你可以在  while (GPS.available()) 之前加上 Serial.println("Before GPS"); 以及之後加上 Serial.println("After GPS")l, 看看是否停在這裡.
可以的話, 多加入 Serial.println("..."); 作 debug, 就可以容易確認停止的地方, 再針對有關程式研究問題所在.
发表于 2014-4-15 20:48:56 | 显示全部楼层
是否电源功率不够,存在电压拉偏复位
 楼主| 发表于 2014-4-17 10:16:11 | 显示全部楼层
pliangpalm 发表于 2014-4-15 20:48
是否电源功率不够,存在电压拉偏复位
不会是电压不够的问题。
 楼主| 发表于 2014-4-17 10:16:52 | 显示全部楼层
由於看不到庫的內容, 假設不會有問題.
而在你的程 ...
没找到,头疼了。
发表于 2014-5-19 17:49:50 | 显示全部楼层
我也遇到类似的问题,姿态传感器+数传就会莫名其妙的死掉,单独使用就没问题
GMT+8, 2026-6-14 15:06 , Processed in 0.042805 second(s), 21 queries .
