查看: 9003|回复: 1
哪位大神帮我修改一下程序好吗?
发表于 2014-4-17 19:20:00 | 显示全部楼层 |阅读模式
我做的是一个串口输入定时时间然后,时间到之后控制13灯亮灭。
#include <DS1302.h>
String month;  //定义一个月份字符串变量
DS1302  rtc(5,6,7);
char buf[50];
char day[10];//定义ds1307接线柱
Time otime;
String comdata = "";
int numdata[4] ={0}, j = 0, mark = 0;
int h1=0;
int m1=0;
int h2=0;
int m2=0;
int h1bt=0;
int m1bt=0;
int h2bt=0;
int m2bt=0;
int sdbt=0;
int sd=0;
void print_time()
  /* Get the current time and date from the chip */
  Time t = rtc.time();
  /* Name the day of the week */
  memset(day, 0, sizeof(day));  /* clear day buffer */
  switch (t.day) {
    case 1:
      strcpy(day, "Sunday");
    case 2:
      strcpy(day, "Monday");
    case 3:
      strcpy(day, "Tuesday");
    case 4:
      strcpy(day, "Wednesday");
    case 5:
      strcpy(day, "Thursday");
    case 6:
      strcpy(day, "Friday");
    case 7:
      strcpy(day, "Saturday");
  /* Format the time and date and insert into the temporary buffer */
  snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",
           day,
           t.yr, t.mon, t.date,
           t.hr, t.min, t.sec);
  /* Print the formatted string to serial so we can see the time */
  Serial.println(buf);
pinMode(13,OUTPUT);
digitalWrite(13,LOW);
rtc.write_protect(false);
  rtc.halt(false);
  /* Make a new time object to set the date and time */
  /*   Tuesday, May 19, 2009 at 21:16:37.            */
  Time t(2014, 4, 17, 19, 06, 37, 3);
  /* Set the time and date on the chip */
  rtc.time(t);
{while (Serial.available() > 0)
        comdata += char(Serial.read());
        delay(2);
         mark = 1;
    /* 以逗号分隔分解comdata的字符串,分解结果变成转换成数字到numdata[]数组 */
       if(mark == 1)
        Serial.print("You inputed : ");
        Serial.println(comdata);
        for(int i = 0; i < comdata.length() ; i++)
            if(comdata[i] == ',' || comdata[i] == 0x10 || comdata[i] == 0x13)
                j++;
                numdata[j] = numdata[j] * 10 + (comdata[i] - '0');
h1=numdata[0];
h2=numdata[1];
m1=numdata[2];
m2=numdata[3];
      mark = 0;j=0;
         comdata = String("");
        /* 清空 numdata */
        for(int i = 0; i < 4 ; i++) numdata[i]=0;
   print_time();
  delay(1000);
if(otime.hr==h1&&otime.min==m1)
digitalWrite(13,HIGH);
if(otime.hr==h2&&otime.min==m2)
发表于 2014-4-17 20:48:52 | 显示全部楼层
沒用過 1302 的庫, 但從程式上看, 有點矛盾.
時間是需要從 rtc.time() 中讀取的.
但.... otime 只定義了, 不用讀取就可以用來比較?
  1. Time otime;
  2. :
  3. :
  4. if(otime.hr==h1&&otime.min==m1)
  5. digitalWrite(13,HIGH);
  6. if(otime.hr==h2&&otime.min==m2)
  7. digitalWrite(13,LOW);
GMT+8, 2026-7-28 23:09 , Processed in 0.082154 second(s), 18 queries .
