查看: 9629|回复: 2
编译时报错误
发表于 2014-4-26 21:37:11 | 显示全部楼层 |阅读模式
void loop(){
  //check and see if a data packet has come in.
  if(ET.receiveData()){
    //this is how you access the variables. [name of the group].[variable name]
    //since we have data, we will blink it out.
    for(int i = mydata.blinks; i>0; i--){
      digitalWrite(13, HIGH);
      delay(mydata.pause * 100);
      digitalWrite(13, LOW);
  delay(2500);
}                                  这是代码
Arduino:1.5.6-r2 (Windows XP), 板:"Arduino Uno"
sketch_apr26a.ino: In function 'void loop()':
sketch_apr26a:3: error: 'ET' was not declared in this scope
sketch_apr26a:6: error: 'mydata' was not declared in this scope
  报告将会包含更多的信息
  "Show verbose output during compilation"
  在 文件>首选项 中启用
错误信息
发表于 2014-4-26 22:12:41 | 显示全部楼层
ET 及 mydata 在程式中沒有定義, 自然要出 error 了.
发表于 2014-4-26 22:28:34 | 显示全部楼层
两个变量用之前要先定义。
GMT+8, 2026-7-28 23:02 , Processed in 0.051945 second(s), 19 queries .
