查看: 17692|回复: 4
12864与库文件U8glib.h
发表于 2014-4-27 14:29:12 | 显示全部楼层 |阅读模式
都是使用的库U8glib.h不同列子会报错?{:soso_e135:}
发表于 2014-4-27 18:42:16 | 显示全部楼层
不是已經說得很清楚了嗎?
 楼主| 发表于 2014-4-27 22:38:40 | 显示全部楼层
Super169 发表于 2014-4-27 18:42
不是已經說得很清楚了嗎?
不会些    现在搞定了    !    谢谢
发表于 2014-12-20 00:48:06 | 显示全部楼层
我也这个问题,怎么解决呢
发表于 2014-12-30 09:41:09 | 显示全部楼层
  1. // setup u8g object, please remove comment from one of the following constructor calls
  2. // IMPORTANT NOTE: The following list is incomplete. The complete list of supported
  3. // devices with all constructor calls is here: [url]http://code.google.com/p/u8glib/wiki/device[/url]
  4. //U8GLIB_NHD27OLED_BW u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  5. //U8GLIB_NHD27OLED_2X_BW u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  6. //U8GLIB_NHD27OLED_GR u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  7. //U8GLIB_NHD27OLED_2X_GR u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  8. //U8GLIB_NHD31OLED_BW u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  9. //U8GLIB_NHD31OLED_2X_BW u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  10. //U8GLIB_NHD31OLED_GR u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  11. //U8GLIB_NHD31OLED_2X_GR u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  12. //U8GLIB_DOGS102 u8g(13, 11, 10, 9);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  13. //U8GLIB_DOGM132 u8g(13, 11, 10, 9);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  14. //U8GLIB_DOGM128 u8g(13, 11, 10, 9);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  15. //U8GLIB_DOGM128_2X u8g(13, 11, 10, 9);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  16. //U8GLIB_ST7920_128X64_1X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
  17. //U8GLIB_ST7920_128X64_4X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
  18. //U8GLIB_ST7920_128X64_1X u8g(18, 16, 17);        // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
  19. //U8GLIB_ST7920_128X64_4X u8g(18, 16, 17);        // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
  20. //U8GLIB_ST7920_192X32_1X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
  21. //U8GLIB_ST7920_192X32_4X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
  22. //U8GLIB_ST7920_192X32_1X u8g(18, 16, 17);        // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
  23. //U8GLIB_ST7920_192X32_4X u8g(18, 16, 17);        // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
  24. //U8GLIB_ST7920_192X32_1X u8g(13, 11, 10);        // SPI Com: SCK = en = 13, MOSI = rw = 11, CS = di = 10
  25. //U8GLIB_ST7920_192X32_4X u8g(10);                // SPI Com: SCK = en = 13, MOSI = rw = 11, CS = di = 10, HW SPI
  26. //U8GLIB_ST7920_202X32_1X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
  27. //U8GLIB_ST7920_202X32_4X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
  28. //U8GLIB_ST7920_202X32_1X u8g(18, 16, 17);        // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
  29. //U8GLIB_ST7920_202X32_4X u8g(18, 16, 17);        // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
  30. //U8GLIB_LM6059 u8g(13, 11, 10, 9);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  31. //U8GLIB_LM6063 u8g(13, 11, 10, 9);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  32. //U8GLIB_DOGXL160_BW u8g(10, 9);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  33. //U8GLIB_DOGXL160_GR u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  34. //U8GLIB_DOGXL160_2X_BW u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  35. //U8GLIB_DOGXL160_2X_GR u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  36. //U8GLIB_PCD8544 u8g(13, 11, 10, 9, 8);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, Reset = 8
  37. //U8GLIB_PCF8812 u8g(13, 11, 10, 9, 8);                // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, Reset = 8
  38. //U8GLIB_KS0108_128 u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 14, 15, 17, 16);                 // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs1=14, cs2=15,di=17,rw=16
  39. //U8GLIB_LC7981_160X80 u8g(8, 9, 10, 11, 4, 5, 6, 7,  18, 14, 15, 17, 16);         // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs=14 ,di=15,rw=17, reset = 16
  40. //U8GLIB_LC7981_240X64 u8g(8, 9, 10, 11, 4, 5, 6, 7,  18, 14, 15, 17, 16);         // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs=14 ,di=15,rw=17, reset = 16
  41. //U8GLIB_LC7981_240X128 u8g(8, 9, 10, 11, 4, 5, 6, 7,  18, 14, 15, 17, 16);         // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs=14 ,di=15,rw=17, reset = 16
  42. //U8GLIB_ILI9325D_320x240 u8g(18,17,19,U8G_PIN_NONE,16 );                          // 8Bit Com: D0..D7: 0,1,2,3,4,5,6,7 en=wr=18, cs=17, rs=19, rd=U8G_PIN_NONE, reset = 16
  43. //U8GLIB_SBN1661_122X32 u8g(8,9,10,11,4,5,6,7,14,15, 17, U8G_PIN_NONE, 16);         // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 cs1=14, cs2=15,di=17,rw=16,reset = 16
  44. //U8GLIB_SSD1306_128X64 u8g(13, 11, 10, 9);        // SW SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  45. //U8GLIB_SSD1306_128X64 u8g(10, 9);                // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are  SCK = 13 and MOSI = 11)
  46. //U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);        // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are  SCK = 13 and MOSI = 11)
  47. //U8GLIB_SSD1306_128X32 u8g(13, 11, 10, 9);        // SW SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  48. //U8GLIB_SSD1306_128X32 u8g(10, 9);             // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are  SCK = 13 and MOSI = 11)
  49. //U8GLIB_SSD1306_128X32 u8g(U8G_I2C_OPT_NONE);        // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are  SCK = 13 and MOSI = 11)
  50. //U8GLIB_SSD1309_128X64 u8g(13, 11, 10, 9);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
  51. //U8GLIB_SSD1327_96X96_GR u8g(U8G_I2C_OPT_NONE);        // I2C
  52. //U8GLIB_SSD1327_96X96_2X_GR u8g(U8G_I2C_OPT_NONE);        // I2C
  53. //U8GLIB_NHD_C12864 u8g(13, 11, 10, 9, 8);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, RST = 8
  54. //U8GLIB_NHD_C12832 u8g(13, 11, 10, 9, 8);        // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, RST = 8
  55. //U8GLIB_T6963_240X128 u8g(8, 9, 10, 11, 4, 5, 6, 7, 14, 15, 17, 18, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7, cs=14, a0=15, wr=17, rd=18, reset=16
  56. //U8GLIB_T6963_240X64 u8g(8, 9, 10, 11, 4, 5, 6, 7, 14, 15, 17, 18, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7, cs=14, a0=15, wr=17, rd=18, reset=16
  57. //U8GLIB_T6963_128X64 u8g(8, 9, 10, 11, 4, 5, 6, 7, 14, 15, 17, 18, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7, cs=14, a0=15, wr=17, rd=18, reset=16
  58. //U8GLIB_HT1632_24X16 u8g(3, 2, 4);                // WR = 3, DATA = 2, CS = 4
  59. //U8GLIB_SSD1351_128X128_332 u8g(13, 11, 8, 9, 7); // Arduino UNO: SW SPI Com: SCK = 13, MOSI = 11, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  60. //U8GLIB_SSD1351_128X128_332 u8g(76, 75, 8, 9, 7); // Arduino DUE: SW SPI Com: SCK = 13, MOSI = 11, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  61. //U8GLIB_SSD1351_128X128_332 u8g(8, 9, 7); // Arduino: HW SPI Com: SCK = 13, MOSI = 11, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  62. //U8GLIB_SSD1351_128X128_4X_332 u8g(76, 75, 8, 9, 7); // Arduino DUE: SW SPI Com: SCK = 13, MOSI = 11, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  63. //U8GLIB_SSD1351_128X128_4X_332 u8g(8, 9, 7); // Arduino : HW SPI Com: SCK = 13, MOSI = 11, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  64. //U8GLIB_SSD1351_128X128_HICOLOR u8g(76, 75, 8, 9, 7); // Arduino DUE, SW SPI Com: SCK = 76, MOSI = 75, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  65. //U8GLIB_SSD1351_128X128_HICOLOR u8g(8, 9, 7); // Arduino, HW SPI Com: SCK = 76, MOSI = 75, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  66. //U8GLIB_SSD1351_128X128_4X_HICOLOR u8g(76, 75, 8, 9, 7); // Arduino DUE, HW SPI Com, 4x Memory: SCK = 76, MOSI = 75, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  67. //U8GLIB_SSD1351_128X128_4X_HICOLOR u8g(8, 9, 7); // Arduino, HW SPI Com, 4x Memory: SCK = 76, MOSI = 75, CS = 8, A0 = 9, RESET = 7 ([url]http://electronics.ilsoft.co.uk/ArduinoShield.aspx[/url])
  68. //U8GLIB_SSD1351_128X128GH_332 u8g(8, 9, 7); // Arduino, HW SPI Com: SCK = 76, MOSI = 75, CS = 8, A0 = 9, RESET = 7 (Freetronics OLED)
  69. //U8GLIB_SSD1351_128X128GH_HICOLOR u8g(8, 9, 7); // Arduino, HW SPI Com: SCK = 76, MOSI = 75, CS = 8, A0 = 9, RESET = 7 (Freetronics OLED)
前面注释这么一大堆东西
选择你用的解开注释
GMT+8, 2026-6-19 01:17 , Processed in 0.044673 second(s), 23 queries .
