查看: 16027|回复: 3
用Arduino写这个ATtiny13的引导出错,帮忙看下哪出错了。
发表于 2014-5-8 23:08:26 | 显示全部楼层 |阅读模式
用的是这个器件:http://item.taobao.com/item.htm? ... &id=19951650310
板子是Arduino Uno
分别用arduino1.0 和 arduino 1.5.6r2 来做都出现错误。
按照这个说明https://www.slanla.com/?blog& ... 268467361344C413D3D 来做的用Arduino写这个ATtiny13引导的时候出现下列错误:
Arduino:1.5.6-r2 (Windows 7), 板:"Arduino Uno"
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
         Double check chip, or use -F to override this check.
processing.app.debug.RunnerException
        at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:305)
        at processing.app.Editor$47.run(Editor.java:2569)
        at java.awt.event.InvocationEvent.dispatch(Unknown Source)
        at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
        at java.awt.EventQueue.access$200(Unknown Source)
        at java.awt.EventQueue$3.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
        at java.awt.EventQueue.dispatchEvent(Unknown Source)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
        at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: processing.app.debug.RunnerException: Wrong microcontroller found.  Did you select the right board from the Tools > Board menu?
        at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:111)
        at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:298)
        ... 15 more
  报告将会包含更多的信息
  "Show verbose output during compilation"
  在 文件>首选项 中启用
发表于 2014-5-9 09:24:49 | 显示全部楼层
悄悄的说。。。这里我买过tiny13。。。也是不能用,回来发现是假货。后来买了真货回来就好了。
 楼主| 发表于 2014-5-9 09:30:28 | 显示全部楼层
啊,这个东西也假,哪有真货卖呀?
发表于 2014-6-22 21:08:59 | 显示全部楼层
怎么在淘宝的328p-pu也不能用啊
GMT+8, 2026-7-28 03:28 , Processed in 0.077927 second(s), 19 queries .
