查看: 24445|回复: 12
实现远程控制家中电器开关的最简单实例
发表于 2014-5-11 08:23:43 | 显示全部楼层 |阅读模式
借鉴了论坛上其他人的经验,加上自己的研究和修改,终于完成了最简单的远程控制!
基础要求:能够看懂一般的arduino程序,对Ethernet类有一定的了解。
实验材料:
arduino UNO x1
W5100 x1
杜邦线若干
LED x1(这里你可以换成任意想控制的元件,如果换成继电器则就可以控制家电)
网络
废话不说,附上源码,同时附上详细注释。
[pre lang="arduino" line="1" file="controlLed_Ethernet"]
//edited by kenan13
#include<SPI.h>
#include<Ethernet.h>
#define LED 8  //这里你可以换成任意想控制的元件,如果换成继电器则就可以控制家电
#define LEN_ON 1
#define LEN_OFF 2
char valc;
String ledstate = "down";
boolean isPost = false;
String post="";
byte mac[]={
  0xAA,0xBB,0xCC,0xDD,0xEF,0x22};
IPAddress ip(222,202,221,11);
EthernetServer server(80);
//执行post命令
void beginControl(String post){
  int val=0;
  if(post=="u=up"){val=LEN_ON;}
  if(post=="n=down"){val=LEN_OFF;}
  switch(val){
  case LEN_ON:
    digitalWrite(LED,HIGH);
    ledstate = "up";
    //Serial.println("Led up!");
  case LEN_OFF:
    digitalWrite(LED,LOW);
    ledstate = "down";
    //Serial.println("Led down!");
  default:
//打印客户端网页代码
void printHtmlCode(EthernetClient client){
  client.print("<html><head><body><form method='post' id='ledform'>Led state:  ");
  client.print(ledstate);
  client.println("<P><input name='u' type='submit' value='up'><input name='n' type='submit' value='down'></P></form></body></head></html>");
void setup(){
  pinMode(LED,OUTPUT);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Ethernet.begin(mac,ip);
  server.begin();
  Serial.print("Start server at ");
  Serial.println(Ethernet.localIP());
void loop(){
  //获取连接到服务器的客户端
  EthernetClient client = server.available();
  if(client){
    //Serial.println("new client");
    //开始读取客户端数据
    while(client.available()){
      valc=client.read();
      //Serial.write(valc);
      if(valc=='\n' && isPost){//判断是否post请求
          valc=client.read();
          post+=valc;
        if(post.length()>1){//打印POST内容
          Serial.println("post is ");
          Serial.println(post);
          Serial.println("post end ");
        if(post.length()>1){//执行post请求代表的命令
          beginControl(post);
          post="";
        printHtmlCode(client);//输出网页代码(注意:必须执行完命令再打印出网页内容,否则不能实时更新状态)
        delay(1);
        client.stop();//停止客户端
        //Serial.println("client disconnected!");
      //判断是否空行(即判断是否是post命令)
      if(valc=='\n'){
        isPost = true;
      else if (valc!='\r'){
        isPost = false;
[/code]
好了,第一次发分享帖,不对的地方请大家指出!互相学习!
发几张实验实图给大家参考一下
关灯状态
开灯状态
实验连接图
 楼主| 发表于 2014-5-15 22:45:42 | 显示全部楼层
是我帖子写得太差了吗?还是其他什么原因?怎么大家都是看帖不回帖啊?
发表于 2014-5-16 10:34:23 | 显示全部楼层
,不太简单吧。。顺便说,没图谁看啊。。。无图无真相
发表于 2014-5-18 13:47:28 | 显示全部楼层
感谢分享,回去试一下
 楼主| 发表于 2014-5-31 14:03:05 | 显示全部楼层
还好啦,其实没那么难理解的,我已经把图加上去啦
发表于 2014-5-31 14:53:20 | 显示全部楼层
先mark一下,慢慢看
发表于 2014-5-31 18:18:02 | 显示全部楼层
先mark一下,慢慢看
发表于 2014-6-1 14:31:30 | 显示全部楼层
谢谢分享!
发表于 2014-8-30 19:19:39 | 显示全部楼层
表示很赞,可否留一个联系方式?共同学习探讨
发表于 2014-12-20 08:00:46 来自手机 | 显示全部楼层
看帖必须回帖,谢谢分享!
发表于 2015-5-28 15:07:53 | 显示全部楼层
你这个如何在外网访问到内网呀
直接输入222.202.221.11吗
太菜了 需要详细的指导呀
发表于 2015-5-28 15:45:09 | 显示全部楼层
你这里所说的远程控制是在局域网内的呀  在外网控制不了的呀
 楼主| 发表于 2015-5-31 23:48:20 | 显示全部楼层
外网也可以控制,不过你要在网络出口做端口映射。这又是另外一个范畴啦,你可以自己百度一下,或参考一个简单的案例http://jingyan.baidu.com/article/1709ad80d599d24634c4f0c2.html
GMT+8, 2026-6-16 17:48 , Processed in 0.039642 second(s), 26 queries .
