查看: 19953|回复: 10
数字接口不够怎么办,可以共用一个接口吗?
发表于 2014-5-15 14:24:59 | 显示全部楼层 |阅读模式
数字接口完全不够用呀,可以共用吗?如果能应该如何做?
发表于 2014-5-15 14:46:04 | 显示全部楼层
你是需要输出复用还是输入复用?
 楼主| 发表于 2014-5-15 14:58:00 | 显示全部楼层
caiwenping 发表于 2014-5-15 14:46
你是需要输出复用还是输入复用?
都需要呀,可有法子呀?不胜感激
发表于 2014-5-15 15:09:16 | 显示全部楼层
我以前用51单片机的时候,用PCF8574T这块I2C芯片扩展了8个IO口,可做输入和输出。
发表于 2014-5-15 15:10:50 | 显示全部楼层
这里贴上我用PCF8574T做i2c扩展8个IO驱动1602的51的一些代码
[pre lang="c" line="1" file="lcd1602_i2c.h"]
#ifndef __STC12C5A_H_
#include "STC12c5a.h"
#endif
#ifndef __I2C_H_
#include "i2c.h"
#endif
#ifndef __INTRINS_H_
#include <intrins.h>
#endif
#ifndef __LCD1602I2C_H_
#define __LCD1602I2C_H_
#define  LINE1                        0
#define  LINE2                     1
#define  LINE1_HEAD            0x80
#define  LINE2_HEAD            0xC0
#define  DATA_MODE            0x28
#define  OPEN_SCREEN        0x0C
#define  DISPLAY_ADDRESS   0x80
#define  CLEARSCREEN    LCD_en_command(0x01)
#define  MSB    0x80
#define  LSB    0x01
unsigned char LCD1602_RS=0x01;
unsigned char LCD1602_RW=0x01<<1;
unsigned char LCD1602_EN=0x01<<2;
unsigned char LCDIO;
unsigned char code PCF8574_ADD=0x4e;
bit LCD_send(unsigned dat);
unsigned char LCD_recv(void);
void LCD_en_command(unsigned char command);//write command function
void LCD_en_dat(unsigned char temp);//write data function
void LCD_set_xy(unsigned char x,unsigned char y );//set display address function
void LCD_init(void);//lcd initize function
void LCD_write_char(unsigned char x,unsigned char y,unsigned char dat);//write lcd a character function
void LCD_write_string(unsigned char x,unsigned char y,unsigned char *s);//write lcd string function
void LCD_custom(unsigned char add,unsigned char *string);
void LCD_switch(bit onoff);
bit busy(void);  //读忙函数
void delay_us(unsigned char us);                //@11.0592MHz
void delay_ms(unsigned char ms);
        if(onoff==1)
                LCDIO=LCDIO|0x08;
                LCDIO=LCDIO&0xf7;
        LCD_send(LCDIO);
        bit busy;
        i2c_start();
        i2c_send(PCF8574_ADD|0x00);
        busy|=i2c_recv_ack();
        i2c_send(dat);
        i2c_stop();
        return busy;
unsigned char LCD_recv()
        unsigned char dat;
        i2c_start();
        i2c_send(PCF8574_ADD|0x01);
        i2c_recv_ack();
        dat=i2c_recv();
        i2c_send_noack();
        i2c_stop();
        return dat;
bit busy(void)
        unsigned char busy;
        LCDIO&=0x08;
        LCDIO&=~(LCD1602_EN|LCD1602_RW);
        LCDIO|=LCD1602_RW|0x80;
        i2c_start();
        i2c_recv_ack();
        i2c_send(LCDIO);
        i2c_recv_ack();
        LCDIO|=LCD1602_EN;
        i2c_send(LCDIO);
        i2c_recv_ack();
        i2c_stop();
        busy=LCD_recv()&0x80;
        LCDIO&=~LCD1602_EN;
        i2c_start();
        i2c_recv_ack();
        i2c_send(LCDIO);
        i2c_recv_ack();
        LCDIO|=LCD1602_EN;
        i2c_send(LCDIO);
        i2c_recv_ack();
        LCDIO&=~LCD1602_EN;
        i2c_send(LCDIO);
        i2c_recv_ack();
        LCDIO&=~LCD1602_RW;
        i2c_send(LCDIO);
        i2c_recv_ack();
        i2c_stop();
        return (bit)busy;
        unsigned char delay=1;
        while(busy());
        LCDIO&=0x08;
        i2c_start();
        i2c_recv_ack();
        i2c_send(LCDIO);
        i2c_recv_ack();
                LCDIO|=LCD1602_EN;
                 i2c_send(LCDIO);
                i2c_recv_ack();
                LCDIO&=0x0f;
                LCDIO|=command&0xf0;
                i2c_send(LCDIO);
                i2c_recv_ack();
                delay_us(delay);
                LCDIO&=~LCD1602_EN;
                i2c_send(LCDIO);
                i2c_recv_ack();
                command<<=4;
                LCDIO|=LCD1602_EN;
                 i2c_send(LCDIO);
                i2c_recv_ack();
                LCDIO&=0x0f;
                i2c_send(LCDIO);
                i2c_recv_ack();
                delay_us(delay);
                LCDIO&=~LCD1602_EN;
                i2c_send(LCDIO);
                i2c_recv_ack();
        i2c_stop();
void LCD_en_dat(unsigned char command)
        while(busy());
        LCDIO&=0x08;
        LCDIO|=0x01;
        i2c_start();
        i2c_recv_ack();
        i2c_send(LCDIO);
        i2c_recv_ack();
                LCDIO|=LCD1602_EN;
                 i2c_send(LCDIO);
                i2c_recv_ack();
                LCDIO&=0x0f;
                i2c_send(LCDIO);
                i2c_recv_ack();
                delay_us(delay);
                LCDIO&=~LCD1602_EN;
                i2c_send(LCDIO);
                i2c_recv_ack();
                command<<=4;
                LCDIO|=LCD1602_EN;
                 i2c_send(LCDIO);
                i2c_recv_ack();
                LCDIO&=0x0f;
                i2c_send(LCDIO);
                i2c_recv_ack();
                delay_us(delay);
                LCDIO&=~LCD1602_EN;
                i2c_send(LCDIO);
                i2c_recv_ack();
        i2c_stop();
void LCD_set_xy(unsigned char x,unsigned char y)
        unsigned char address;
        if(y==LINE1)
                  address=LINE1_HEAD+x;
             address=LINE2_HEAD+x;
        LCD_en_command(address);
        LCD_set_xy(x,y);
        LCD_en_dat(dat);
    LCD_set_xy(x,y); //set address
    while(*s)  // write character
                LCD_en_dat(*s);
                s++;
        unsigned char i;
        unsigned char base_add=0x40;
        base_add+=(add*8);
        for(i=0;i<8;i++)
                LCD_en_command(base_add+i);
                LCD_en_dat(*string);
                string++;
void LCD_init(void)
        delay_ms(50);
        LCD_send(0x30);
        LCD_send(0x34);
        LCD_send(0x30);
        delay_ms(5);
        LCD_send(0x30);
        LCD_send(0x34);
        LCD_send(0x30);
        delay_us(160);
        LCD_send(0x30);
        LCD_send(0x34);
        LCD_send(0x30);
        LCD_send(0x20);
        LCD_send(0x24);
        LCD_send(0x20);
        LCD_en_command(0x28);
        LCD_en_command(0x01);
        LCD_en_command(0x06);
        LCD_en_command(OPEN_SCREEN);//open display (enable lcd display)
        LCD_en_command(DISPLAY_ADDRESS);//set lcd first display address
        LCDIO=0x08;
void delay_ms(unsigned char ms)                //@11.0592MHz
        unsigned char i, j;
        while(ms--)
                        _nop_();
                        i = 11;
                        j = 190;
                        do
                                        while (--j);
                         while (--i);
void delay_us(unsigned char us)                //@11.0592MHz
        while(us--)
                        _nop_();
#endif
[/code]
发表于 2014-5-15 15:15:49 | 显示全部楼层
在arduino下,用wire写i2c驱动的代码应该更容易,这样i2c可以带上八块扩展芯片,通过SDA/SCL这两个I2C端口可以扩展到8*8=64口IO
 楼主| 发表于 2014-5-15 15:27:13 | 显示全部楼层
caiwenping 发表于 2014-5-15 15:15
在arduino下,用wire写i2c驱动的代码应该更容易,这样i2c可以带上八块扩展芯片,通过SDA/SCL这两个I2C端口可 ...
谢谢了,有电路图吗?
发表于 2014-5-15 15:38:16 | 显示全部楼层
wdb_9955 发表于 2014-5-15 15:27
谢谢了,有电路图吗?
http://wenku.baidu.com/link?url=HW5UBZqAKLCfIakHQ26E0-uxyIyvfFlDUSHqOgxf5fuXZFoXhayLvsjteBu_EXmmxZJgdc0PFVz_XZDftF89EPXC4rY-5BPW6DKU_6IdBAG
发表于 2014-5-15 18:09:35 | 显示全部楼层
模拟接口可以当数字接口用。A0-A5(14-19)。{:soso_e182:}
 楼主| 发表于 2014-5-19 16:18:30 | 显示全部楼层
谢谢大家了
发表于 2014-8-28 20:51:24 | 显示全部楼层
请问能不能附带一个i2c.h?
GMT+8, 2026-7-27 10:27 , Processed in 0.036347 second(s), 20 queries .
