楼主 |
发表于 2014-5-28 16:04:55
显示全部楼层
#include "U8glib.h"
#include "Wire.h"
#define BMP085_ADDRESS 0x77 // BMP085的I2C地址
const unsigned char OSS = 0; // 采样设置
// 校准值
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5用于计算bmp085GetTemperature(...),它也同时用于bmp085GetPressure(...)
// 所以Temperature(...)必须在Pressure(...)之前声明
long b5;
//short temperature;
float pressure=0.0;
U8GLIB_SSD1306_128X64 u8g(2, 3, -1, 4,5);
void draw(void) {
u8g.setFont(u8g_font_osb18);
u8g.setPrintPos(0, 20);
u8g.print("Pressure:");
u8g.setPrintPos(2, 55);
u8g.print(pressure/100.0);
u8g.print("hPa");
void setup(void)
Wire.begin();
bmp085Calibration();
void loop(void) {
pressure = bmp085GetPressure(bmp085ReadUP());
delay(100);
u8g.firstPage();
do {
draw();
} while( u8g.nextPage() );
void bmp085Calibration()
ac1 = bmp085ReadInt(0xAA);
ac2 = bmp085ReadInt(0xAC);
ac3 = bmp085ReadInt(0xAE);
ac4 = bmp085ReadInt(0xB0);
ac5 = bmp085ReadInt(0xB2);
ac6 = bmp085ReadInt(0xB4);
b1 = bmp085ReadInt(0xB6);
b2 = bmp085ReadInt(0xB8);
mb = bmp085ReadInt(0xBA);
mc = bmp085ReadInt(0xBC);
md = bmp085ReadInt(0xBE);
// 计算压力
// 校准值必须是已知的
// B5在bmp085GetTemperature(...)需要使用,所以必须先调用。
// 返回值以Pa为单位
long bmp085GetPressure(unsigned long up)
long x1, x2, x3, b3, b6, p;
unsigned long b4, b7;
b6 = b5 - 4000;
// 计算B3
x1 = (b2 * (b6 * b6)>>12)>>11;
x2 = (ac2 * b6)>>11;
x3 = x1 + x2;
b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
// 计算B4
x1 = (ac3 * b6)>>13;
x2 = (b1 * ((b6 * b6)>>12))>>16;
x3 = ((x1 + x2) + 2)>>2;
b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
b7 = ((unsigned long)(up - b3) * (50000>>OSS));
if (b7 < 0x80000000)
p = (b7<<1)/b4;
p = (b7/b4)<<1;
x1 = (p>>8) * (p>>8);
x1 = (x1 * 3038)>>16;
x2 = (-7357 * p)>>16;
p += (x1 + x2 + 3791)>>4;
return p;
// 在BMP085的'address'中读取一个字节
char bmp085Read(unsigned char address)
unsigned char data;
Wire.beginTransmission(BMP085_ADDRESS);
Wire.write(address);
Wire.endTransmission();
Wire.requestFrom(BMP085_ADDRESS, 1);
while(!Wire.available()) ;
return Wire.read();
// 从BMP085读取两个字节
// 第一个字节是从'address'
// 第二个字节是从'address'+1
int bmp085ReadInt(unsigned char address)
unsigned char msb, lsb;
Wire.requestFrom(BMP085_ADDRESS, 2);
while(Wire.available()<2);
msb = Wire.read();
lsb = Wire.read();
return (int) msb<<8 | lsb;
// 读取未补偿的温度值
unsigned int bmp085ReadUT()
unsigned int ut;
// 在寄存器0xF4写入0x2E
// 这个用来请求进行温度读取
Wire.write(0xF4);
Wire.write(0x2E);
// 至少等待4.5ms
delay(5);
// 从寄存器0xF6与0xF7读取两个字节
ut = bmp085ReadInt(0xF6);
return ut;
// 读取未补偿的压力值
unsigned long bmp085ReadUP()
unsigned char msb, lsb, xlsb;
unsigned long up = 0;
// 写入0x34+(OSS<<6)到寄存器0xF4
// 请求气压数据读取
Wire.write(0xF4);
Wire.write(0x34 + (OSS<<6));
// 等待转换,延迟时间依赖于OSS
delay(2 + (3<<OSS));
// 读取寄存器0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
Wire.write(0xF6);
Wire.requestFrom(BMP085_ADDRESS, 3);
// 等待数据变为可用
while(Wire.available() < 3);
msb = Wire.read();
lsb = Wire.read();
xlsb = Wire.read();
up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
return up;
