mega2560作为主机连接W5100接上网线通过yeelink发送六路开关信号到从机,怎么实现 - /*
- Yeelink sensor client power switch example
- #include <SPI.h>
- #include <Ethernet.h>
- #include <Wire.h>
- #include <math.h>
- byte buff[2];
- // for yeelink apiapi.yeelink.net LED /v1.0/device/10964/sensor/18179/datapoints
- #define APIKEY "47412e01ab744a131cb8da0e64d7e040" // 此处替换为你自己的API KEY
- #define DEVICEID 10964 // 此处替换为你的设备编号
- char flag =0; //定义开关循环控制变量
- //#define SENSORID1 19581 // 此处替换为你的传感器编号
- //#define SENSORID2 19582
- String SENSORID[]={"19581","19582"}; // 把sensor ID 依次替在这里,程序定义为数组,几个开关就写几个
- byte ledPin[]={5,6};
- // assign a MAC address for the ethernet controller.
- byte mac[] = { 0x00, 0x1D, 0x72, 0x82, 0x35, 0x9D};
- // initialize the library instance:
- EthernetClient client ;
- char server[] = "api.yeelink.net"; // name address for yeelink API
- unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
- boolean lastConnected = false; // state of the connection last time through the main loop
- const unsigned long postingInterval = 3*1000; // delay between 2 datapoints, 30s
- String returnValue = "";
- boolean ResponseBegin = false;
- void setup() {
- pinMode(5, OUTPUT);
- pinMode(6, OUTPUT);
- for(int i=0;i<2;i++) //I<7,几个开关,就把7改成几,其实就是循次数
- { pinMode(ledPin[i],OUTPUT);}
- Wire.begin();
- // start serial port:
- Serial.begin(57600);
- // start the Ethernet connection with DHCP:
- if (Ethernet.begin(mac) == 0) {
- Serial.println("Failed to configure Ethernet using DHCP");
- for(;;)
- else {
- Serial.println("Ethernet configuration OK");
- void loop() {
- // if there's incoming data from the net connection.
- // send it out the serial port. This is for debugging
- // purposes only:
- if (client.available()) {
- char c = client.read();
- // Serial.print(c);
- if (c == '{')
- ResponseBegin = true;
- else if (c == '}')
- ResponseBegin = false;
- if (ResponseBegin)
- returnValue += c;
- if (returnValue.length() !=0 && (ResponseBegin == false))
- Serial.println(returnValue);
- if (returnValue.charAt(returnValue.length() - 1) == '1') {
- Serial.println("turn on the LED");
- digitalWrite(ledPin[flag], HIGH);
- else if(returnValue.charAt(returnValue.length() - 1) == '0') {
- Serial.println("turn off the LED");
- digitalWrite(ledPin[flag], LOW);
- returnValue = "";
- flag++;
- // if there's no net connection, but there was one last time
- // through the loop, then stop the client:
- if (!client.connected() && lastConnected) {
- Serial.println();
- Serial.println("disconnecting.");
- client.stop();
- // if you're not connected, and ten seconds have passed since
- // your last connection, then connect again and send data:
- if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
- // read sensor data, replace with your code
- //int sensorReading = readLightSensor();
- Serial.print("yeelink:");
- //get data from server
- // getData();
- if (flag<2)
- getData();
- else
- //put data to server
- if(flag=3) {flag =0;}
- // store the state of the connection for next time through
- // the loop:
- lastConnected = client.connected();
- // this method makes a HTTP connection to the server and get data back
- void getData(void) {
- // if there's a successful connection:
- if (client.connect(server, 80)) {
- Serial.println("connecting...");
- // send the HTTP GET request:
- client.print("GET /v1.0/device/");
- client.print(DEVICEID);
- client.print("/sensor/");
- //client.print(SENSORID2);
- //SENSORID[flag]={"19581","19582"};
- client.print(SENSORID[flag]);
- client.print("/datapoints");
- client.println(" HTTP/1.1");
- client.println("Host: api.yeelink.net");
- client.print("Accept: *");
- client.print("/");
- client.println("*");
- client.print("U-ApiKey: ");
- client.println(APIKEY);
- client.println("Content-Length: 0");
- client.println("Connection: close");
- client.println();
- Serial.println("print get done.");
- else {
- // if you couldn't make a connection:
- Serial.println("connection failed");
- Serial.println();
- client.stop();
- // note the time that the connection was made or attempted:
- lastConnectionTime = millis();
复制代码 怎么插入24l01的代码来控制从机? |
