查看: 37716|回复: 23
enc28j60+yeelink利用browseUrl()函数l获取开关状态
发表于 2012-9-26 16:03:52 | 显示全部楼层 |阅读模式
2013年4月3日,ethercard库作者已经更新库,稍微修改了下代码适应新库。
要下班了先发代码,有问题后面问吧,库文件也做了点修改,主要是etherCard库文件的browsurl函数没法添加头文件内容。请下载附件库文件。
不过这样改库文件不是办法,有空还是重新整个库。
  1. #include <EtherCard.h>
  2. #define REQUEST_RATE 5000 // milliseconds
  3. // ethernet interface mac address
  4. static byte mymac[] = {
  5.   0x74,0x69,0x69,0x2D,0x30,0x31 };
  6. #define STATIC 0  // set to 1 to disable DHCP (adjust myip/gwip/dnsip values below)
  7. #if STATIC
  8. // ethernet interface ip address
  9. static byte myip[] = {
  10.   10,21,0,193 };
  11. // gateway ip address
  12. static byte gwip[] = {
  13.   10,21,0,1 };
  14. // remote dns ip address
  15. static byte dnsip[] = {
  16.   10,11,5,25 };
  17. #endif
  18. // remote website name
  19. char website[] PROGMEM = "api.yeelink.net";
  20. char urlBuf[] PROGMEM = "/v1.0/device/xxx/sensor/xxx/";
  21. char apiKey[] PROGMEM = "U-ApiKey: xxxxxxxxxxxxxxx";
  22. byte Ethernet::buffer[500];   // a very small tcp/ip buffer is enough here
  23. static long timer;
  24. String switchStatus;
  25. // called when the client request is complete
  26. static void my_result_cb (byte status, word off, word len) {
  27.   String reply=(const char*)Ethernet::buffer + off;
  28.   switchStatus = reply.substring(reply.length()-2,reply.length()-1);
  29.   Serial.print("<<< reply ");
  30.   Serial.print(millis() - timer);
  31.   Serial.println(" ms");
  32.   Serial.print("Switch Status:");
  33.   Serial.println(switchStatus);
  34.   Serial.println();
  35. }
  36. void setup () {
  37.   Serial.begin(57600);
  38.   Serial.println("\n[getStaticIPorDHCP]");
  39.   if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
  40.     Serial.println( "Failed to access Ethernet controller");
  41. #if STATIC
  42.   ether.staticSetup(myip, gwip, dnsip);
  43. #else
  44.   if (!ether.dhcpSetup())
  45.     Serial.println("DHCP failed");
  46. #endif
  47.   ether.printIp("IP:  ", ether.myip);
  48.   ether.printIp("GW:  ", ether.gwip);
  49.   ether.printIp("DNS: ", ether.dnsip);
  50.   while (ether.clientWaitingGw())
  51.     ether.packetLoop(ether.packetReceive());
  52.   Serial.println("Gateway found");
  53.   timer = - REQUEST_RATE; // start timing out right away
  54. }
  55. void loop () {
  56.   ether.packetLoop(ether.packetReceive());
  57.   if (millis() > timer + REQUEST_RATE) {
  58.     timer = millis();
  59.     if (!ether.dnsLookup(website))
  60.       Serial.println("DNS failed");
  61.     ether.printIp("Server: ", ether.hisip);
  62.     Serial.println("\n>>> REQ");
  63.     ether.browseUrl(urlBuf, "datapoints", website,apiKey, my_result_cb);
  64.   }
  65. }
同样切个串口图吧
评分
参与人数 1 +5 收起 理由
幻生幻灭 + 5 经测好用!
查看全部评分
发表于 2012-9-26 17:52:57 | 显示全部楼层
呵呵~!
谢谢张老师了~!正好在找这方面的资料
 楼主| 发表于 2012-9-26 18:00:56 | 显示全部楼层
不客气,共同学习,这个是静态地址和dhcp通用的代码,只需更改#define STATIC的值, 1为静态,0为动态获取ip地址
发表于 2012-9-26 18:04:14 | 显示全部楼层
>>> REQ
<<< reply 78 ms
Switch Status:
Server: 202.136.56.203
>>> REQ
<<< reply 79 ms
Switch Status:
>>> REQ
<<< reply 79 ms
Switch Status:
为什么我返回的值是空的?
 楼主| 发表于 2012-9-26 18:10:21 | 显示全部楼层
奇了个怪了。。你在
  1. String reply=(const char*)Ethernet::buffer + off;
后加个
  1. Serila.println(reply);
看看返回那些东西。
发表于 2012-9-26 22:10:46 | 显示全部楼层
学习了~~~谢谢无私贡献
发表于 2012-9-27 11:25:57 | 显示全部楼层
我设置20秒发送一个数据,10秒读取一个数据
貌似会产生冲突
既发送不出去又读取不到数据
发表于 2012-9-27 12:14:30 | 显示全部楼层
张老师威武
 楼主| 发表于 2012-9-27 14:06:49 | 显示全部楼层
貌似会产生冲突
既发送不出去又读取不到数据
不会的,你代码的问题
发表于 2012-10-9 09:26:48 | 显示全部楼层
返回404 是怎么回事 。说我的迷药错误。 但是我是复制过去的
发表于 2012-10-13 09:39:58 | 显示全部楼层
DNS一定要配置吗
 楼主| 发表于 2012-10-13 13:43:50 | 显示全部楼层
xl_1120 发表于 2012-10-13 09:39
DNS一定要配置吗
如果访问ip地址的话不需要,访问域名就要配置dns
发表于 2013-1-1 15:36:13 | 显示全部楼层
用了你的附件,串口打印出 Serial.println( "Failed to access Ethernet controller");就不动了,连里面的实例都一样,还回原来的库就好的,请教是什么问题呀
 楼主| 发表于 2013-4-3 18:58:38 | 显示全部楼层
应某人要求,更新了下代码。
发表于 2013-4-3 20:50:54 | 显示全部楼层
zcbzjx 发表于 2013-4-3 18:58
应某人要求,更新了下代码。
很荣幸成为某人: ) 。 测试成功!
GMT+8, 2026-7-28 01:59 , Processed in 0.083756 second(s), 27 queries .
