用自带卡尔曼滤波的串口6050模块制作的低成本自平衡小车,串口6050模块+小车底盘+L298驱动+Arduino uno R3,成本一百多。小车可以非常稳定地停在中间位置,控制算法非常简单,只用了比例控制就可以实现稳定控制了,足见串口6050模块测量精度之高。后续正在开发稳定度更高的自适应PID控制算法,希望有兴趣的朋友一起来玩,抛砖引玉,希望朋友们贡献出更稳定的控制代码。
淘宝地址:http://item.taobao.com/item.htm?id=19785706431
扫盲(大神请略过):
卡尔曼滤波:一种高效率的递归滤波器(自回归滤波器), 它能够从一系列的不完全及包含噪声的测量中,估计动态系统的状态。能够有效提高测量精度。
比例控制:即电机的输出电压,也就是PWM的脉宽宽度正比于小车的倾角。
PID控制:在工程实际中,应用最为广泛的调节器控制规律为比例、积分、微分控制,简称PID控制。
arduino源码:
[pre lang="arduino" line="1" file="MPU6050"]/*
This code is used for connecting arduino to serial mpu6050 module, and test in arduino uno R3 board.
connect map:
arduino mpu6050 module
VCC 5v/3.3v
TX RX<-0
TX TX->1
GND GND
note:
because arduino download and mpu6050 are using the same serial port, you need to un-connect 6050 module when you want to download program to arduino.
Created 14 Nov 2013
by Zhaowen
serial mpu6050 module can be found in the link below:
unsigned char Re_buf[11],counter=0;
unsigned char sign=0;
int M11=5;
int M12=6;
int M21=9;
int M22=10;
float a[3],w[3],Angle[3],T;
short sAccelerat[3],sAngleVelocity[3],sAngle[3],sT;
Serial.begin(115200);
pinMode(M11,OUTPUT);analogWrite(M11,0);
pinMode(M12,OUTPUT);analogWrite(M12,0);
pinMode(M21,OUTPUT);analogWrite(M21,0);
pinMode(M22,OUTPUT);analogWrite(M22,0);
void SetMotor(float v1,float v2)
if (v1>255){v1=255;analogWrite(M11,0);analogWrite(M12,v1);}
else if (v1>0) {analogWrite(M11,0);analogWrite(M12,v1);}
else if (v1>-255) {analogWrite(M12,0);analogWrite(M11,-v1);}
else {v1=-255;analogWrite(M12,0);analogWrite(M11,-v1);}
if (v2>255){v2=255;analogWrite(M21,0);analogWrite(M22,v2);}
else if (v2>0) {analogWrite(M21,0);analogWrite(M22,v2);}
else if (v2>-255) {analogWrite(M22,0);analogWrite(M21,-v2);}
else {v2=-255;analogWrite(M22,0);analogWrite(M21,-v2);}
Serial.print(Angle[0]*10);Serial.print(" ");
Serial.print(v1);Serial.print(" ");
Serial.print(v2);Serial.print(" ");
float k=20;
if (sign==0) return;
sign=0;
SetMotor(Angle[0]*k,Angle[0]*k);
Serial.print("angle:");
Serial.print(Angle[0]);Serial.print(" ");
Serial.print(Angle[1]);Serial.print(" ");
Serial.print(Angle[2]);Serial.print(" ");
Serial.print("T:");
Serial.println(T);
//delay(100);
void serialEvent() {
while (Serial.available()) {
//char inChar = (char)Serial.read(); Serial.print(inChar); //Output Original Data, use this code
Re_buf[counter]=(unsigned char)Serial.read();
if(counter==0&&Re_buf[0]!=0x55) return; //第0号数据不是帧头
counter++;
if(counter==11) //接收到11个数据
counter=0; //重新赋值,准备下一帧数据的接收
switch(Re_buf [1])
case 0x51:
a[0] = float(short(Re_buf [3]<<8| Re_buf [2]))/32768*16;
a[1] = float(short(Re_buf [5]<<8| Re_buf [4]))/32768*16;
a[2] = float(short(Re_buf [7]<<8| Re_buf [6]))/32768*16;
case 0x52:
w[0] = float(short(Re_buf [3]<<8| Re_buf [2]))/32768*250;
w[1] = float(short(Re_buf [5]<<8| Re_buf [4]))/32768*250;
w[2] = float(short(Re_buf [7]<<8| Re_buf [6]))/32768*250;
case 0x53:
Angle[0] = float(short(Re_buf [3]<<8| Re_buf [2]))/32768*180;
Angle[1] = float(short(Re_buf [5]<<8| Re_buf [4]))/32768*180;
Angle[2] = float(short(Re_buf [7]<<8| Re_buf [6]))/32768*180;
T = float(short(Re_buf [9]<<8| Re_buf [8]));///340.0+36.25
sign=1;
}[/code]
废话不多说,直接上图了吧。
串口6050模块:
小车拆解图,中间绿色模块为串口6050模块
小车上电工作情况展示,两轮自平衡,静若处子。弱光拍摄,曝光时间较长,得益与串口6050模块高精度的姿态解算精度,稳定效果超乎想象。
